Question about Maytag Neptune FAV6800AW Top Load Washer
Error code nD, won't go into spin cycle - Maytag Neptune FAV6800AW Top Load Washer
  • 526 Answers
Is the Machine a FAV6800A or a FAV9800A?
Do you want to DIY the fix?
The nd error code = No Drain error code.
You could have drain line clog, an issue with the drain pump or a stuck pressure switch. Do you hear the machines drain pump turn on and pump out water before entering lnto the spin cycle? Is there water left in the tub with the nd error code? If you can provide feedback on the questions above I will help guide through the troubleshooting steps.
You will need the Service Manual to troubleshoot.
The FAV6800AW/FAV9800AW Service Manual for reference. Sears Parts Direct for reference.
Rich
Posted on Dec 04, 2009
  • Rey reyes
    Rey reyes May 28, 2014
    I have cleaned the drain pump and hose. But still the same , the motor is working as i can hear and feel that its working. However it wont spin.
6ya staff
SOURCE:
TheMazz
Kevin
  • 79 Answers
SOURCE: ND Error code
Error code "nd" means it is not draining. Click on this link to get the user manual:
http://laundry.manualsonline.com/manuals/mfg/maytag/mah24.html
Then click on "GET THIS MANUAL" to download the manual.
Not draining can be caused by the controller, pump, solenoid valve, or clogged drain.
If this information was useful, please select YES to the first to rating questios. Good Luck and thank you!
Posted on Oct 22, 2009
aborcass
Ron Coons
  • 2651 Answers
SOURCE: Maytag Neptune Error COde "nd"
"nd" refers to a No Drain issue . check for rstriction in pump assy, restricted drain hose loose wire at pump, bad pump
Posted on Mar 03, 2008
Anonymous
I had a similar problem until it finally gave up draining altogether. I took the drain pump apart and found that a quarter was jammed in the pump after it broke a vain off. I don't know how the quarter got past the basket but this was definitely my problem.
Posted on Mar 29, 2008
Eugene Merritt
  • 298 Answers
SOURCE: Washer will not spin; displays nd error
(nd) stands for no drain check the pump,and drain hose
for clogs
Posted on Dec 24, 2007
Anonymous
  • 55 Answers
SOURCE: Stops mid-cycle, does not drain, displays nd error code?
Hello.
That code is telling you that the unit is draining to slow. After 15 minutes it is not below the low water level and will not spin out. The best repair for this is to replaced the pump on your unit.
Posted on Jul 15, 2009
What does error code nd indicate?
Error code nd = Not Draining. Don't know what machine you have, but if you are in any way "handy" you'll manage it. Go for the simple solution first. Filter (usually lower left on the front) is it clear. Do you hear the drain pump going before the spin cycle. The motor that drives the pump is a very simple affair and can stick (or just not work, ever again) when sticking intermittently gives faults like, not going into spin cycle (sometimes), the door not being allowed to open or nd code. Either through the front or up from underneath gives access to the hoses from drum base to pump etc. Check there is no debris blocking any of them. The one from the drum base on some machines reduces in diameter a wee ways from the drum. Creates a nice place for a blockage. Have look on youtube it'll give you confidence, if you need it.
Hope this is of help,
H
Apr 03, 2016 | Washing Machines
Maytag MAH8700 pumps the water out of the tub but then tries repeated to keep pumping water and will not progess to spin cycle. It will do this and then sometimes (not all) display the nd error code.
Edit your posting to add Make and Model#
Check your manual for troubleshooting tips or search online for your make and model# to find a manual.
Contact the company of your product or a local appliance shop to ask them.
May 12, 2015 | Washing Machines
How to fix nd code
ND means no drain. The issue could be using the wrong detergent. IT could also be something stuck in the filter or the pump.
Aug 05, 2017 | Washing Machines
Amana front load washer error code "nd". Door is
Hello there and welcome to fixya
From what you're describing it sounds like the drain pump is blocked. The nd error code indicates "no drain". If the unit can't drain it won't spin. You're going to have to slide the washer out far enough to remove the rear panel; be careful not to damage the floor. Once you get the rear panel off you will see the pump. Be sure to have plenty of towels & a small container to catch water. I am sending you instructions from the service manual to remove and replace the pump. Another possibility is the drain line is blocked or something is stuck in the tub to pump hose.
Nov 05, 2011 | Amana Washing Machines
Spin cycle (7min) starts, spin perfectly, try to let water go (doesn't work) then reset back to 7min... ND code does appear but not all the time
ND error code means no drain check the pump filter check the pump and check the drain line that goes from the oulet port coming out of the outter tub to the pump and also check the drain hose leaving the pump that goes out of your washer as well. If you have any further questions message me back I await your rely
Thank you,
Rick
Oct 28, 2011 | Maytag Neptune MAH5500B Front Load Washer
Someone put some heavy things in it and it stopped mid-cycle. We removed the heavy objects, and then attempted to drain the leftover water by putting it on "rinse and spin." It never really...
The ND error code on a digital Neptune front load washer. The ND code means 'No Drain' and it is probably just something caught in the pump. Sometimes this is a early sign of the pump going out or a control board issue.
Nov 23, 2010 | Maytag Neptune MAH5500B Front Load Washer
My washer stops before the rinse cycle because it can't seem to drain enough to start the spin cycle. I just had the drain motor replaced one month ago. I get the error code nd. I can sto the cycle and...
I'd love to say yes! The machine is stopping because it will not drain. This is what the nd code means. Therefore, it will not rinse (add more water) or spin because the water level is already too high and to try to "spin it out" would put too much pressure on the machine with that much water in it. Drain out the water by putting the drain hose below the level of the washer (this takes forever) and call your repair man back!
Feb 18, 2010 | Maytag MAH8700A Front Load Washer
Spin cycle doesn't get all the water out of clothes. Making a grinding noise when in spin cycle
Sounds like a Clutch issue. Can you confirm your model number is it a FAV6800A or FAV9800A?
Any error codes to the display ie. dC, uC, nd, etc?
Dec 04, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Hello.
Jul 15, 2009 | Maytag Neptune MAH9700 Front Load Washer
for clogs
Dec 24, 2007 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune FAV6800AW Top Load Washer Logo
1,619 people viewed this question
Top Maytag Washing Machines Experts
jimorris77
Sheldon Dedek
Bill Long
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
