Washing Machines Logo
Posted on Jan 17, 2008
Fisher & Paykel Smart Drive 601 - won't turn on
HI
my washing maching - after being unplugged for a couple of days - has decided that it will NOT turn on. I have checked the power point that it is plugged into, other appliances work OK. I don 't get any lights or anything.
Do you have any idea what the problem could be?
Thanks
  • 1 more comment
  • Loopy69 Jan 18, 2008
    Hello, Me again!
    I think we found the problem - a pesky blown fuse!
    Cheers
  • Spider666 Jun 21, 2008
    I have power but no motor drive.
  • karrakaz Apr 16, 2009
    My Fisher & Paykel Smart Drive 058 won't show lights or work - just a day after working fine! The power point works, the machine does not. Never had a problem before.
    karrakaz
Anonymous
Level 1:
  • Contributor 2 Answers
  • Posted on Oct 07, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
2703
Points
Hi I Have this washing machine (FISHER & PAYKEL Smart drive 601) hasn't been turn on for 4 yrs. now I'm going to use it coz my other machine broke.when I turn it on ,at starting it only distribute a little amount of water then it span the drum slowly.after about 5 mins. The lights of cold and hot keeps blinking and beeping.sounds like an error beeps .The power and all the light button still on except the cold and hot lights keeps blinking then just stop workin. can u help me what the problem could be.
Thanks
Jaf
Fisher and Paykel Smart Drive Pride 5.5 washing machine will not pump water out...makes a beeping noise when trying to pump water out.
I own and have repaired my smart drive washer. The water pump is very simple to remove on these machines. Unplug the machine and drain as much water from it as possible. There's a small plastic locking tab on one side of the pump. Gently pry it away from the body of the pump and twist the housing until it comes free from the metal pump housing anchor plate. Unplug the pump from it's connection and remove it. Found a guide that should help you -
How to Drain Washing Machine That Won Empty Cares Appliances
Fisher paykel smart drive 601
Hi just read your post.When the machine beeps a series of lights will light up on the wash progress line of lights. Staring from left to right the long wah is number 1 and the spin light is number 8 which lights sre on when the machine beeps, is it 2, 4 and 8 or 1, 3 and 7 etc.Please reply with this information and I sure I can help you. Regards LU
Washing machine
It could be a faulty lid switch in the blue display board.
The smaller one of the two has the lid switch in it.
Unable to wash using hot water -F & P Smart Drive 608 (GW608U)
Check that the valve behind the washer for the hot water is open, it will be labeled red and should indicate which way to turn to open it typically counterclockwise.
5helpful
Fisher & Paykel Smart Drive 7.5 washing machine.
Unplug the machine have someone tilt the machine back and look under the machine for a little fan on a motor give it a turn to see if it spins it might just be sticky or it may need replacing.
3helpful
2answers
Fisher & paykel smart drive 601, power to board, won't fill
If it isn/t doing anything at all it could be a faulty start switch on the display panel. Also make sure you can hear an audible click when you open and close the lid. The lid switch on a 601 is actuated on the right hand back of lid adjust as required. Hope this helps.
29helpful
4answers
Fisher & paykel washing machine fault codes
I have a Fisher & Paykel GW609AU Smartdrive Excellence 6.5 Washing Machine that would start then stop then start then stop a few more times before eventually beeping.
I fixed it by bypassing(joined the white and yellow wire) the trip out switch which is located under the control module(one screw to remove).Now it Works.
Top Washing Machines Experts
john h
