I have a Panasonic KX-t7731 phone device. My caller id is not showing name or number of the caller.Phone service provider told us that it might be something wrong with a device.What should i do?
Since CID display to the phone comes from the Panasonic phone SYSTEM, you might try looking inside the cabinet to see if it has a caller ID card. The part ends in 93.
It also requires some programming. If you post your model number, I might have a CID card if yours is missing.
Carl
CID on Panasonic systems require a CID card, spefically TD-193,TA62493,TA82493,or TAW5193 that fit in the corresponding systems. Since a 7731 is BACKWARD compatible with ALL Panasonic systems, if you have a KXT-61610,30810, 123211, then you DON'T have CID available.
Just a quick follow up. It still comes down to you POSTING YOUR SYSTEM MODEL. Programming is different for each unit and to help you out, 7731 isn't the SYSTEM model number.
My panasonic model is kx-t7731.It worked fine till recently.Now caller id is not working and I'm trying to get an instruction how to reset caller id through programming
