According to their tech support...
Remove the water tank and re-seat. Unplug for 30 seconds and replug.
Fixed mine this way with the same issue.
Terry
Worked for me too. I had to take off the water reservoir, turn the keurig on and then is says add more water. I replace the reservoir and it works again!
WOW, that just worked for me too! Mine is brand new and brewed about 7 cups and then just turns itself off and when I turn it back on it will say "not ready" and then turn off again. I returned my last one for doing that and then about cried when my new one did it tonight. I decided to google the problem and found this. I took the water container out and put it back in and turned on the power and it immediately started to take in water again and stay turned on. I think for some reason the water was "stuck". I even called Keurig and they said to just return my last one.
Thanks! I hope this solves everything. I would hate to return it again. This is my 3rd one because my very first one was cracked!
Problem is a flow valve, older models have it before pump later models after pump.The later models have a metering spring that is in a flexible rubber housing and the spring is too stiff to allow water into the heating chamber. Not easy to get to to replace and clamp. You can get out by stretching the flexible line.Remove the spring and cut down until a light blowing into will allow water to pass but not too much so the backflow is compromised.
Wow, thanks Terry! I had the same problem and did what you suggested and it worked!
Tried the water tank solution...still kept shutting off. So...I tried another solution that someone talked about...I reset the clock AND I did a start/shutoff time. It has worked like a charm for a week!
thank you everyone! I tried it without unplugging it but it shut off on me! So i unplugged it, turned it on and waited for it to ask for water, i put the tank back on and it was fixed
I'm on my second one and I'm taking it back. I messed with it one morning for 20 minutes and it kept shutting off. Not worth the headache for a cup of coffe when you have so many other choices.
Mine was not staying turned on either. Very frustrated because I LOVE my Kurig. Removed the water holder, put it back and it worked perfectly! Thanks everyone!
Sure have experienced this ... this is my second machine ... first one returned this one will most likely be garbage since it is the second time ...Don't know the cause but I do know it always happens at the worse time possible ... Keurig and I are definitely done
We use ours at our office. the machine goes into this problem weekly, our solution is to have our office supply vendor (who we bought it through) bring a new one with our weekly order and we return the current one which I'm sure Staples damages out back to the vendor. This option is NOT ENVIRONMENTALLY SOUND!! But did anyone think these machines ever were? The machines are just as disposable as the K-Cups.
It didnt work for me. I m frustrated, grrrr
Worked for me, too!
I have two machines....one to use at my daughter & son-in-law's when I come down every week, & one at my home. I took the older one to my home cuz it's noisier. It recently quit pulling water in - worked perfectly until then. I think I may have to have that one replaced.
However, I ran into the "turning off" problem quite early with the new one...what works for me is if I turn off the unit just as it starts to draw in water, & leave it off until I'm ready for more. I usually only have a large mug in the morning, so it's not a problem.
Thank you so much. I had the same problem and this saved me!
Here is a tip that I wrote that will give you some things to try that will help you get your Keurig coffee brewer working again.
Keurig Coffee Brewer not making a full cup of Coffee
heatman101
Keurig
heatman101
lllll;
I took off the resevoir and unplugged machine. The place where the reservoir sits had link on it. I removed it and now it does not shut off and I get a full cup of coffee..
I met it had lint.....
I plugged in my Keurig 155 and it starts to heat the water and then suddenly shuts off, has anyone experienced this?? And what is the solution? I turn it back on it heats the water and shuts off again.ThanksD
it says not ready, so we wait and it would shut off. but wont pump any water.
