Exercise & Fitness Logo
Posted on Dec 04, 2009
Need a new pulse monitor for Cat eye ergociser
Need a new pulse monitor for Cateye ergociser ec-3500. PNR.780-1101 EC-3500 Pulse Sensor (Long).
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Dec 23, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
1128
Points
Go to: www.fitnessgeneration.com.au they sell parts for the Cateye ergocisors.
regards
Erwin
E404 error code?
P0404 Dodge - Exhaust Gas Recirculation Position Sensor Performance Early Exhaust Gas Recirculation (EGR) systems component s include and EGR Valve, and Engine Control ?odule (EC?) Controlled Vacuum Switch Valve or EGR Solenoid and an EGR Vacuum ?odulator. Depending on the engine and driving conditions, the EC? will control the EGR Solenoid which will operate the EGR Vacuum ?odulator to regulate the opening and closing of the EGR Valve.
The EGR system on recently built vehicles uses a step motor to control the flow rate of EGR from exhaust manifold. This motor has four winding phases. It operates according to the output pulse signal of the EC?. Two windings are turned ON and OFF in sequence. Each time an ON pulse is issued, the valve opens or closes, changing the flow rate. When no change in the flow rate is needed, the EC? does not issue the pulse signal. ? certain voltage signal is issued so that the valve remains at that particular opening.
When peddeling ec3000 cateye ergociser bike it has good tension but after a few revolutions it lets go and free wheels.
Sounds like the belt is loose on the pulleys? Maybe something else, but you have to get inside it to check.
* Refer to the service manual (the EC3200 is almost the same as a EC3000) for hints :Page 4,5,19,20. Read this manual.
http://d3f8w3yx9w99q2.cloudfront.net/1952/Cateye-Fitness-EC-3200-Stationary-Bike/Cateye_Fitness_EC-3200_Stationary_Bike_Service_Manual.pdf
* Take out every screw holding the white plastic cover and the crank bottom bracket cover. Also take off the screws that hold the black seat post and handle bar post covers together. Now the covers should come apart to access the guts.
* Inside there is a belt system and chain system.
* Belt system: Check there are no loose nuts on the axles that connect to the pulleys. If there are, try to pull the pulley so that belt is tensioned as you tighten the nut.
* If the plastic teeth are loose on the big belt pulley (that's bad), you may have to try to glue it back to the metal part of the pulley. Don't be sloppy and get glue on the teeth... A runny epoxy may be able to get into the interface between the plastic teeth and metal part.
* If the belt is worn out you may be able to find it with a WWW search or from an industrial supplier like
McMaster Carr
https://www.sdp-si.com/eStore/CoverPg/Drive_Components.htm
* Chain system: Check the chain freewheel (the small one) is working correctly.
Need toestraps for Cateye EC-1200
I want to know the price of Cateye ergociser display Model ec-3000
Looking for replacemt program cards or safety card for Cateye Treadmill ECT220
go to www. fitnnesrepairparts.com or www. doctortreadmill.com or www. treadmillpartszone.com
God bless you
I recently purchased a cateye ergociser EC 5000. Does it have a card that is required to make it work
Hello not sure you ever got an answer, but I'm thinking of buying one myself, on Craigslist. I researched and found this link to the official manual and it says a yellow start card comes with the packaging and it has to be inserted. Here's link to manual, if it helps. http://www.manualslib.com/manual/399069/Cateye-Ec5000e.html?page=7#manual
I need a replacement pedal foot strap for a cateye ergociser ec-3000
I want to replace the display of Cateye ergociser.How much prices of the display ?
The Cateye ec t220 treadmill in our exercise room no longer has a functioning display. Nothing lights up. It is possible a power surge blew out a main circuit or something of that nature- we are on a...
If your treadmill was struck by a power surge unfortunately there is no way of fixing it, in fact it is a fire HAZARD. Basically a back-flow of electrical current has fried the appliance from the inside.
A good way of checking if this was the problem is to check smaller appliance's around the house that were plugged in around the same time the treadmill stopped working. Even if appliences are turned off at the switch they can still be effected.
If you have no problems with any smaller appliance then we can more or less rule out a power surge. Have you tried dissembling the plug, changing the fuse, moving the treadmill them plugging it in to a different socket? .......yes?
Then as this model is no longer in production i suggest you phone 303-443-4595 for advice as this is the North America helpline for cateye.
I need to know about a parts distributor for this unit in Europe, Spain or Portugal: I need to buy the rear foot.
You will need to contact the world headquarters for CATEYE.
International
CatEye World Headquarters
2-8-25 Kuwazu
Higashi Sumiyoshi-ku, Osaka 546, JAPAN
Attention: CatEye Customer Service
Phone: 81-6-6719-7781
Fax: 81-6-6719-2362
Email: [email protected]
1helpful
Starting to grind. need schematics to take shell off to try and trouble shoot
call them direct with the serial # and they should have schematics. 800-323-7524 ask for tech support
Top Dmm Exercise & Fitness Experts
Sportsmith LLC
Sportsmith LLC
john h
ADMIN Andrew
ADMIN Andrew
Are you a Dmm Exercise and Fitnes Expert? Answer questions, earn points and help others
