If there is no water in washer, and it will not spin, I suggest you remove the motor, and check the brushes.
If they are less than 3 or 4mm long, they need replacing.
Hope this helps.
Testimonial: "barkencoa, i think you were right. checked the brushes which i think were ok. now running on full cycle. no water=no spin THANK YOU!!!!!!!!!!!!!!!!!!!"
Here you go, probably more than you wanted J
Energy Consumption per Wash: 190kW/yr warm wash
Water Consumption per Wash: 72.6l
ApplStandard AS/NZS
2040.2 (2000)
Brand BOSCH
Cap 6.50
CEC_ 190.00
Cold Wat Cons 72.60
Conn_Mode Cold
Country Thailand
Depth 600
Height 820
Hot Wat Cons 0.50
Model No WFL2000AU/WFL2080AU,
WFL2400AU
New SRI 4.39
New Star 4.00
Prog Name Cotton
40C, 1000RPM
Sold_in Australia,
New Zealand
Test Prog Time 123.60
Tot Wat Cons 73.10
WEI .658
