Apex Digital GB4308 43" Rear Projection EDTV-Ready Television Logo
Posted on Jan 17, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Double Vision We just turned our t.v. on and it had double vision... It was working fine before that, could it be the picture tube..
Anonymous
Level 3:
President:
  • Master 4,402 Answers
  • Posted on Jan 17, 2008
Anonymous
Master
Level 3:
President:
Answers
4402
Questions
0
Helped
1710862
Points
8129
Convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Tmtmail.co.ukmy samsung projection tv has double vision and i dont know how to amend the lens can yu please help thank you
double vision in a rear projection tv has several reasons. one is convergence magnets are out of tune. u need to tune them which is back side of picture tubes. u please observe that which color is producing the double vision. the lens are firmly fixed & therefore need not to adjust. other option is to adjust the convergence of tv by going to service mode by remote.
We recently moved the tv and now when we turn it on it has double vision. It kinda looks like a 3d movie. What could be the issue? Is it worth fixing?
If tv picture was fine before moved then check dry/ cold solder joints/ connections on convergence output ICs and nearby circuit area.
Local tv repairman will resolder loose/ dry solder connections to solve double vision picture problem.
TV worth fixing if picture is good.
Thanks.
5helpful
4answers
Double vision
I have a 60SBX72B and the colors are all separated like triple vision. Is there a way that I could fix this
2helpful
2answers
I have a 53inch RCA big screen tv, we have double vision
Is the convergence adjustment option still listed on the on screen menu or has it disappeared? Thats a very easy chassis to repair so let me know if the option has disappeared or not and I can asssist you with how to fix it.
1helpful
2answers
Put it together myself now wont focus past 5 ft and has double vision i tryed using the adjustment knobs and stillno luck
loosen the the thingy behind the lens adjustment, you can turn it clockwise or anti-clockwise which it will go down or up, thats it..problem solve for your 5ft focus problem..in the double vision, you gotta line up the eyepiece center to your both eyes..problem solve again
Apr 29, 2009 • Optics
1helpful
3D like view on my screen
you ned to replace both convergence ICs they are STK392-570 you can get replacement ICs at the following link with free installation instructions.
http://servicemanuals.vstore.ca/
Phillips 60" projection TV Double vision
This is a convergence problem and is either bad connections at the convergence ICs or defective ICs. If you can solder, you can repair this yourself. Let me know if you wish to repair this and I can provide you with additional details.
Dan
Picture Problem!! and its not convergence (Double vision except for middle of screen)
Could be pin correction circuit or your picture tubes could be worn out . Sometimes when the crt's get weak the edges seem not as clear as the center of the screen . Give model number if you think the pin correction may be your problem but, the tv is pretty old and avg. life for them is 12 to 15 years when the picture tubes start to degrade . Good luck
Top Apex Digital Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
Are you an Apex Digital Televison and Video Expert? Answer questions, earn points and help others
