You can take the front panel off of the washer by using credit cards. You use credit card to push the clips in by the sides of the wash machine. The pressure value hose is connected to the outer tube of the washer, it is a tan color tube. Pull that off and you can see if there is any junk inside the hose. If there is you can use a q-tip and rubbing alcohol to clean. After you clean the hose, carefully blow into the hose. If you hear clicking sound then you got it working. If you don't it is your switch. They are not that bad replace. I am wanting to say around $60 or so.
