Tip & How-To about Heating & Cooling
Boiler Leaking Water - The Boiler Leak may not be the boiler
Went on one call today and had another query by Facebook about this so I though why not write an article about it. Both persons were very concerned as they saw water dripping from theirs boilers. A closer inspection for both showed that it had nothing to do with the boiler its self.
There are many things that can make water leak from your boiler. If you know for sure that the water is coming from a hole in the sections then you may have a serious problem. Usually though there is an easy fix for that also, more on that in another article. Both boilers today were leaking water from the relief valve.
This valve is design to relieve the excess pressure from the boiler in case of a build up of extra pressure in the boiler. The extra pressure can come from a number of different things. A few of the causes may be a bad expansion tank, a bad fill valve or pressure reducing valve, or an open bypass valve. The bypass is easy, just close it and relieve the extra pressure. The others are not as easy.
Your expansion tank is simply a tank that allows water from the system to go in and out according to the pressure in the system. This tank contains about ½ air which acts as a cushion to absorb the extra volume of water that is created as the water is heated. Hotter water takes up more space or volume, so it needs a place to go to when it is heated. If the expansion tank is totally full of water then, it will push water out of the relief valve. Changing your expansion tank will fix the problem.
If the reducing valve or fill valve is leaking by then you can also get extra pressure in the system. A normal heating system will only run 10-20 psi pressure. Most well systems or city water is way higher than that. If the pressure in your boiler gets over 30 psi then it will begin to relieve the extra pressure by dripping water.
If you have a drip from your boiler this is what you check. First the expansion tank, the reducing valve, and the bypass valve that bypasses the fill valve. This valve is usually installed to quick fill the system, or purge the water lines of air.
Often there is just a small problem that looks like a big problem. Do not get excited and methodically check through the possibilities. You will usually find that the problem is not nearly as bad as you first thought that it was.
Heating & Cooling Logo
2answers
how do i close a facebook business acount and open a personal account?
There are no business accounts. Business pages are created by having and existing personal account, then adding the page to your personal account.
How to Create Facebook Business Page in 5 Simple Steps Tutorial
Facebook friends went missing
On the setting try to go to the menu of "Block" and write the same name of your friend that was missing then click block. When that name appeared on the list of block person or persons, then unblock. Both parties must do the same way. That's what I do and it work.
when i put my username and password in facebook and hit login it it cant load the facebook server
Hello and Welcome to FixYa!
Yes, I can see tons of such queries suddenly coming up.
The FB-Servers are down this time, please be patient it will be up soon.
Concerned, Nooh.
2answers
error on facebook page
Please do explain your query in a bit detail, what exactly is the error script you are facing... Waiting for your response...
Concerned.
2answers
how do i change a personal facebook account, with a Business Name, to a Business type account?
Fro my research on your topic it seems a lot of people have had the same problem. I also read that Facebook took this feature option away.
READ THIS ARTICLE BELOW: It might be your only answer
____________________________________________________________
Want to set up a business presence on Facebook but don’t want to have a personal presence? No problem! A little known feature of Facebook is the ability to create business accounts. However if you already have a personal account, keep in mind that you cannot create a separate business account. However if you would like to avoid setting up a personal account and would like to keep things professional, you can take a few steps to get things configured.
From the business account you will be able to manage Facebook advertising campaigns as well as Facebook Pages. In order to get your business account set up, all you’ll need to do is create a Facebook Ad or create a Facebook Page. After you’ve created the page or advertisement, Facebook will ask you to enter your login information or the option to select “I do not have a Facebook account”. At that point all you need to do is enter your business email address and date of birth. That’s it! Now you have a business account on Facebook. One thing that you should keep in mind is that if you have a personal account and go through this process, there is a very good chance Facebook will shut down both accounts. In other words: don’t create multiple accounts. I have received multiple emails from people that don’t want to set up personal accounts though so for those individuals that have not explored Facebook, you can proceed to set up a business account.
While I think advertising on Facebook or creating a page doesn’t make much sense without thoroughly understanding how Facebook works, the company has at least provided the option for those that don’t want a personal account.
Top Heating & Cooling Experts
Paul Carew
john h
