I have recently purchased a PS50P91 Samsung 50" 1080p HD TV. The TV seems to makes a buzzing noise which comes from the back of the TV, however it is loud enough to hear from 3m away when watching low volume broadcasts like the news.
I have done some research and contacted Samsung but I'm unable to get a firm answer. I have been told things like room acoustics, TV distance from the wall and various other reasons can amplify the buzzing noise. I understand that plasmas do make a low level buzzing noise when on but it shouldn't be loud enough to hear over the TV.
Any suggestions?
I had this problem and just fixed it its to do with the backlight, if you go into settings and find it turn it up to maximum and the buzz will go or turn of power save mode because it automatically turns the backlight to minimum which also makes the same annoying buzz
This is the worst issue ever! it is so annoying! my tech came out and he said either return it or live with it! now that i know there is a buzzing noise all i do is listen for it! so im going to return it for a panasonic.
The transformer is resonating. Get it replaced, Don't do it yourself.
I have the same problem I can hear buzzing over the volume of the tv into the 30 range. I've had a tech out 3 times and he's coming out for a fourth. He's changed to power supplies and is bringing the 3rd next visit. From what I've read it has either to do with power supplies or grounding strips.
I have the very same problem but with an LG 42" plasma
Got the same problem here. Just bought a Samsung 50" PS50HD.
Buzzing noise is quite annoying!
The "True Surround Sound" doesn't seem very "surround" either!
Buzzing noise is more worrying than annoying!
The "True Surround sound" isn't all that "surround" either!!
I have the same issues, I hope someone can solve this soon, it's driving me insane!!!
mine too..
volume too low on samsung 50" flat screen. Volume ok but not loud enough. even though at "100" .Happened when programming remote (successful). The TV volume works at the bottom of the screen - same as remote - but can't get to the TV volume (upper right corner). Maybe have that set too low.
