Question about Toshiba 32AV502R LCD TV
With the Toshiba 32AV502R 32 in. HDTV LCD TV, can
With the Toshiba 32AV502R 32" HDTV LCD TV, can one remove the on screen volume display? It can be annoying when it covers up subtitles and the like.
  • lrea77 Dec 07, 2009
    Thanks, but I just can't see the Volume menu. Just Setup Video Audio Preferences Locks, and it's not on any of them...
    New Friend:
How do you change your HD setting say 480i to 1080p...
Posted on Dec 25, 2009
    Guru:
  • 1,738 Answers
It is the main menu, then there should be a volume menu and it should be in there about shutting of the volume bar.
Posted on Dec 07, 2009
Anonymous
SOURCE:
Toshiba tv no power
I have never heard of or seen a "power down button". Unplugging the TV and holding the power button for a minute or so sometimes will do a hard reset on the TV, is that what you seen?.
On your problem, chances are there was a spike that came down the power line when your power went out and it took out at a minimum the main fuse in the TV, you can remove the back and replace that fuse on the power board and see if it comes on or blows the fuse again, if it blows then look for a bad rectifier or shorted FET transistor in the hot section.
Nov 26, 2017 | Toshiba 32AV502R LCD TV
Toshiba 32 AV502R LCD TV has a horizontal red line in the middle of the screen, then after a while you can see two colors
Sounds like a defective LCD panel, but I would recommend a diagnoses to get a second opinion.
Oct 27, 2012 | Toshiba 32AV502R LCD TV
I have atoshiba 32 inch television and the motherboard gone bad. please give me places were to find a replacement ?
Well it depends on what the TV model is.
For the 32AV502R in particular if you can't find a replacement main board or if you are not actually certain the problem is in the main board to begin with it may be worth checking the failure symptoms and proposed repair service offerred here:
http://www.coppelltvrepair.com/p/427/repair-service-for-toshiba-32av502r-intermittent-shutdown-random-shutoff-not-powering
Hope that helps!
Sep 03, 2011 | Toshiba 32AV502R LCD TV
Toshiba 32av502r lcd tv keeps turning on & off, will not stay on. screen is black, but the power light keeps blinking.
The power supply board is the problems and the causes.That the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Nov 21, 2010 | Toshiba 32AV502R LCD TV
Toshiba 32av502rz 32 " lcd, I keep getting half screen with vertical lines. Its unwatchable, tv was made in august of 09.
Hi
the problem you are describing seems to come from the screen panel your tv is a Samsung made and a very common problem so I would suggest you contact Toshiba even
if its out of waranty.
good luck
Sep 27, 2010 | Toshiba 32AV502R LCD TV
RE: Toshiba 32AV502R 32
NO,Ur tv have problems.The Main Tuner Signal is dead,have burn electronics componnents.Still under warrenty call for service.Not Tries websites Shopjimmy.com,Ebay.com to buy a refurbish Tuner signal board for the replacement.
Mar 17, 2010 | Toshiba 32AV502R LCD TV
Toshiba 32AV502R LCD TV Logo
621 people viewed this question
Top Toshiba Televison & Video Experts
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
