Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Things to check first for a camera that won't turn on are battery contact points, and micro switches that are located on the battery and memory card doors. Troubleshooting tips on other things that need to be checked may be seen here. These tips won't work for every case, but they're worth a try.
when i just touch the lens gently to remove the dirt then the lens cant retarct.and when i turned it on it says lens error restart the camera. pls help me
This model came out before the picture transfer protocol (PTP) was developed for direct interface between digital cameras and Windows/Mac computers. Also, there are no drivers available for anything newer than Windows XP. Your best option is to purchase a USB card reader ($10 or less) that can accept a CF card. You just take the card out our your camera, plug it in to the reader, and Windows 'sees' the card as another drive on your system. You can then view and download the photos.
this usually happens when lens are stuck, the reason for this is duct, could be the camera has dropped down, or the gears are jammed, now to make it work, while switching your camera on, try to tap very gently, near the lens, should make it shake in prior to make lens come out from jammed position, try this several times...it should work, if it does not, then take it to qualified service tech
