Question about Symbol MC9000-G Portable Terminal
Freezes on the warm boot screen - Symbol MC9000-G Portable Terminal
    Scholar:
  • 38 Answers
Hello jumpmaster. When an MC90XX does this, it means that something has gone wrong with the Operating System file execution. Sometimes a cold-boot can fix it (instructions below). If not, then there is a problem with the OS files. If you purchased your MC90XX from Motorola/Symbol you should be able to download a copy of your OS to reinstall. The file will include a readme.txt that will walk you through the process. I hope this solves your problem. Good luck!
  • To Cold Boot
  1. Press the primary battery release to partially eject the battery.
  2. While the battery is partially released: simultaneously press and release the trigger and power button.
  3. Push the battery back in until it clicks.
  4. The MC90XX should power up and start it's boot-sequence.
Posted on Jan 06, 2010
6ya staff
SOURCE:
Samsung ln26a330j1d lcd tv picture freezes or just goes to white screen
BAD CAPACITORS!!!!!!!!!!!!!!!!!!!! FIND'EM
SWOLLEN ON THE TOP!!!!
Nov 14, 2013 | Televison & Video
CPU freezes on boot up
try reset CMOS.or re-wiring the electrical wires,make sure they are seated tight.
Jul 24, 2013 | Biostar M7VIG-400 (M7VIG 400-COMBO4)...
2001 Volkswagen passat computer screen freezes and the car don't want to shift. It never did it in the summer time but now it's 29 degrees out and it doing it more the colder it is, I let the car heat
These are 2 separate problems. First, the shift lever problem is a problem of LUBRICATION and Condensation. Get the vehicle into a warm area and open the shift lever boot to expose the internal parts. Then using WD40 or CRC spray, spray all the moving parts while working the lever back and forth. Moisture between the metal parts condenses and freezes! THe screen freezing may be caused by similar things, like moisture. For it you need to get to the contacts that supply the screen and blow them out with DRY compressed air!
Dec 30, 2012 | Cars & Trucks
Dell d600 freezes intermittantly
sounds like the hard disk drive is slow to spin up. Sometimes older drives don't get all the way up to speed at boot, then with repeated restarts, the drive warms a bit and the spindle friction drops allowing full speed on the drive.
Try running HDD Diags the 1st boot of the day Fn +power button, see if you get any diag failure. Generally, a drive has to be within 3% of rated drive RPM (5400 or 7200) to function
Jan 11, 2010 | Dell Latitude D600 Notebook
My mc3090 freezes up on the startup screen
The next step would be to try and reload the Operating system, I think the MC3000 requires power to reload the OS so you would need a charging cradle. If that doesn't work then you can send it in for repair. If you need help I am a Motorola Business Partner and can help with this, I can give you my #.
Jun 03, 2009 | Symbol MC3090
Console freezes during boot up
Try running recovery if that dosent work then its a hd issue mine did the same and i had to send it to sony to have them fix it.. was free from me cause of warnty.
Dec 21, 2008 | Sony Playstation 3 (PS3) Console
Hp Pavillion laptop freezes when I install secondary memory
You may not put all together the 256 and 512, the system encountered error when two memory are not equal size and not equal brand.
Either you select 2 units 256 memory or either 2 units 512. or use only 1 unit 512 memory so that no freezes will happen.
Jan 17, 2008 | HP Pavilion dv6000z Notebook
450sx4 freezes half way thru setup
E-mail CHID: 5736 So basically it freezes trying to intialize the setup. ... try rebooting the computer into safe mode and run the setup through safe mode.
Good Luck, Please dont for get to Vote/Thank You.
Dec 23, 2007 | Gateway 450SX4 Notebook
Frozez LCD Screen
hi im jules_09,theres a problem with the copier because ussually after turning it on it warms up for seconds or a minute,but when it freeze at wait the warm up time is too long,see if if you can get the error code,if there is a error code it the lcd check how long is its warm up time.if it take too long.if you can repair it check the voltage at the power supply board going to the main logic board.
Nov 05, 2007 | Canon imageRUNNER 8500 Copier
Symbol MC9000-G Portable Terminal Logo
2,338 people viewed this question
Top Symbol Computers & Internet Experts
Ekse
Vish Iyer
Vish Iyer
Thomas F. Schneider
Are you a Symbol Computer and Internet Expert? Answer questions, earn points and help others
