Question about JVC AV-56WP74 56" Rear Projection HDTV-Ready Television
Jvc av56wp74 rear projection tv
I think i have a convergence problem. the screen seems like it has double vision and the auto convergence doesn't help any. when i try to manually converge it the red and blue lines come together but the green seems off center and wavy. i've called some repair places but the average estimates are 300-400 dollars. i need help
  • ak_vader May 05, 2008
    I have same problem but mine is the blue thats messed up.  When you use the link below my blue looks exactly bowed in like the blue lines in the picture doing the convergance.  Bought a relacment Convergence out PWB (ssb-5068a-m2) from a JVC service center and it didnt change a thing.  What else could cause the blue to be bowed at top and bottom like that?  When i try to manually converge it i can move all red and green both sideways and up and down, however the blue only lets me move it left and right i can not move it up and down at all.  And it's off pretty far in the center top and bottom but close to aligned at the edges.  Any ideas?
    President:
  • 4,402 Answers
Http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Posted on Jan 18, 2008
6ya staff
SOURCE:
I have a jvc av56wp74 double immages in red and
Ur tv have convergence problems,it dead.U must have soldering tools and know how to solders to fix the convergence problems.U must replaced 2 STK convergence ICS,and some or all it resistors.Tries websites like Tv repair World.com,Tvrepairkits.com to buy a convergence kit to repair it ur self.The shop will cost u $300-350 for parts and labors.
May 05, 2010 | JVC AV-56WP74 56" Rear Projection...
57HX81 projection tv,color is mostly red and picture is double.
This is a convergence output IC problem. convergence board would have to be removed - remove and replace 2 STK IC's and check the surrounding resistors. Shops usually charge between $200-$300
Sep 28, 2009 | Toshiba 57H81 57" Rear Projection...
KP-46WT510 Red lines and double vision
yes the convergence problem leaves a shadow of red or blue like an outline around the picture, sometimes part of the screen some times the entire screen.
Jun 26, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
Double vision on tv with purple and green colors
This television set, as well as most rear-projections, is prone to convergence driver problems. There are two large chips (STK392-110's) in the TV that need to be replaced, as well as some resistors that are likely damaged as well. Any competent TV repair shops should be able to repair this TV for 200-300 dollars. It is important to note that if the back of the TV is taken off without the proper prep., the Digital input (DVI) will be disabled permanently.
Hope this helps you...
Dec 30, 2008 | JVC AV-56WP74 56" Rear Projection...
AV56WP74 jvc tv
Repalce the Two STK392-110 Convergence ICs. You can get replacements at the following link with free instructions.
http://servicemanuals.vstore.ca/
Dec 16, 2008 | Televison & Video
I art JVC 46 inche double vision
If you do not have hand soldering skills or know how to use a multimeter, I would suggest to replace the whole assembly.
If you know how to solder you can just replace 2 ICs that are mounted on the big black heatsinks and possibly 1 or more resistors.
Click here to find the entire assembly for your TV.
Good Luck.
May 24, 2008 | JVC AV-56WP74 56" Rear Projection...
Convergance problems?
did you adjust the convergence
on the menu?
Jan 11, 2008 | Hitachi 53UDX10B 53" Rear Projection...
Tv screen waves and is double
No. You have bad convergence output ic;s and probably at least 1 burnt resistor. This liely will have to be reconvergec in the servcie menu after the aprts are changed.
I’m happy to help further over the phone at https://www.6ya.com/expert/dewayne_4a10eab6caecdb92
Jul 12, 2007 | JVC AV-56WP30 56" Rear Projection...
JVC AV-56WP74 56" Rear Projection HDTV-Ready Television Logo
273 people viewed this question
Top JVC Televison & Video Experts
Todd Hill
Todd Hill
matt martin
matt martin
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
