Question about Amana 16.8 cu. ft. / 476 liter Upright Freezer Deepfreeze AFU1705B
Amana self defrosting upright freezer - drain plug
Drain plug is clogged with ice. I have cleaned out the freezer and turned it off but it is so cold in our garage I don't think it will thaw for a couple of days. Is there a way to remove the plug? Thanks
  • Anonymous May 14, 2008
    Amana Upright Freezer----frost free-----16.7 cu.ft---AUF170KW---purchased Oct. 1998------Opened freezer noticed a build up of ice on very bottom in the middle----have lowered the setting one number-----
  • Anonymous Mar 14, 2014
    whirlpool upright freezer drain line plugged. how do I get the old one out?
    President:
  • 1,314 Answers
The subject is a Eureka Model 350 hand held steamer that can be found at Lowes and other places for around $49.95. With this steamer you can thaw out an evaporator as quick as if you were using a heat gun or hair dryer but without the slightest concern about melting plastic or wiring. By using steam instead of pouring water (yes many still do) there is little to clean up. With the many attachments it comes with there are other uses (i.e. cleaning, thawing drains, thawing IDI fill tubes, etc.). The steam also makes the replacement IDI fill tube (rubber end) more pliable and easier to complete the installation when used at the end.
This unit has a trigger and can be used to blow out a stopped up drain on a refrigerator by letting the pressure build up a little then blow through the drain with one of the attachments. As for thawing out evaporators it had a fine jet tip for actually CUTTING through solid ice.
Another great use for this tool is refrigerator door gaskets. The hot steam works faster than a heat gun with out the worry.
Note: Do not aim steam directly onto the plastic freezer liner. The rapid temperature change could damage the liner.
Posted on Jan 18, 2008
6ya staff
SOURCE:
Where is the drain plug on the Amana upright freezer? How do I get to it to check for clog and clean out?
The best thing for you to do is unplug the machine and let the ice completely thaw. After that you gain access to the top of the drain you'll have to remove the back wall and the drain hole is under the evaperator. From behind the machine you should be able to see the bottom half of the drain. it sometimes has a rubber piece on it that resembles a duck bill. It that is indeed there remove it because that would be the source of the problem.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Apr 23, 2012 | Amana Freezers
Ice buildup in bottom of freezer--puddle of water on floor
this sounds like your freezer is operating properly, except that the drainage of the water when going through the defrosting mode is not draining properly, pooling on the bottom of the freezer and then freezing. Check the drainage hose for the defrost in the lower pan. I would remove everything, place in ice chest, let the unit completely thaw out and then inspect. I hope this is beneficial.
Aug 05, 2009 | Freezers
Drain tube and floor of uprite freezer is plugged with ice. Have previously thawed with a heat gun and it freezes up again in a week or two. The freezer is in our south facing garage, one car parks...
I bet you don't have that problem in the summer,It is freezing cause of the outside air in the garage gets below freezing. For a quick fix install a heater wire they make them for gutters and plumbing and just run it down the length of the tube and that will do it,short of heating your garage or insulating it
Mar 31, 2011 | Kenmore Freezers
Maytag Performa PTB2153GR making a clicking noise and food is thawing in freezer, fridge not staying cold
check no ice around pump unit. then try manual defrost both.no hot water. clean filters/drain holes.dry as best you can then switch on.
use thermometer to check temp -20c in freezer
Feb 07, 2010 | Freezers
My Maytag side by side fridge freezer is leaking at the bottom and ice is collecting at the bottom of the freezer. I cannot find any model number but think it's about 6 years old
The drain is clogged behind the wall in the freezer you can do one of three things take the back wall inside the freezer off and thaw the drain in the bottom and clear it out,Pay someone else to do this,or you can mover your food for a day unplug the unit open the freezer door and leave it off for 24 hours allowing the ice to clear from the drain,seems to happen about every five or six years with Maytags..
Aug 12, 2009 | Maytag Freezers
Frozen drain line from top freezer to drip pan
Hi, Remove everything in the freezer. Get as much ice out as possible with out using sharp object. You will need to remove the rear evaporator panel inside the freezer and locate the drain hole below the evaporator. The safest way is to use a hair dryer. Once you can get to the drain hole and get the ice down inside the drain thawed (a few glasses of hot water usually gets the job done) Try and run a wire (I use a hose or biasting seringe) and get that drain hole flushed out real good. Sometimes it takes 45 minutes or so. After that is cleaned out, put the rear panel back on and you should be all set.
I hope I have helped you. Please let me know if I can be of more assistance.
Thanks
Vic
May 12, 2009 | Freezers
Maytag Frostfree Freezer ice at bottom
hi thanks for the question .The drain tube is clogged up. Pull fridge away from wall, remove back panel, clean all coils. let thaw 24 hrs. find drain tube by drain tray clean tube to freezer thanks the appliance doc
Sep 28, 2008 | Freezers
Water does not drain from the Freezer during the defrost cycle
hi thanks for the question the drain hose goes to the underneath by the compressor thaw out the freezer and clean the drain hose this will solve the problem thanks the appliance doc
Sep 12, 2008 | Frigidaire 13.7 cu. ft. / 388 liter...
GIBSON DEEP FREEZE IS RUNNING BUT EVERYTHING IS THAWING OUT
Might try unplugging for a few hours and then plug it back in. There is a possibility that it slugged the compressor and there is a restriction in the line. Sometimes when the compressor fails to stop running in cold air the liquid gets back to the compressor. It can cause a bit of gunk to be picked up out of the oil and carried to the expansion line and plug up the line. Maybe turning it off will let the plug fall free and not replug the line. Worth a try anyway.....
Feb 07, 2008 | Freezers
Amana 16.8 cu. ft. / 476 liter Upright Freezer Deepfreeze AFU1705B Logo
1,109 people viewed this question
Top Amana Freezers Experts
John Tripp
John Tripp
Dennis Boxerman
Gil Shultz
Are you an Amana Freezer Expert? Answer questions, earn points and help others
