SOURCE: hotpoint washing machine keeps tripping electric
First unplug your washer. Check the ground on the washer and make sure it isn't loose; this would be a good time to inspect the wiring harness for any problems. Next check the outlet (turn off the electric to that breaker first) make sure all the wires are tight and are making good contact; pay special attention to the neutral (white) wire. If that seems fine, and you are comfortable with going into you breaker panel, turn off that breaker and check the hot (the wire on the breaker) to make sure it isn't loose and then check the neutral wire. If either of these wires seem loose tighten them down....a loose wire will move when a load is put on it and cause the breaker to trip. If all seems normal and washer is still tripping the breaker you might want to replace the breaker.....they can go bad. Good luck!
Hi
The washing machine is obviously
drawing too much current for the breaker to handle. This could be due to the
washing machine drawing more that it should or because the breaker cannot
handle the current the machine needs, coupled with the other machines on the
ring main. If the fuse on the plug of the washing machine does not blow, then it
could be that there are too many appliances on the ring main. The fuse on the
machine may not blow however, if the breaker has a faster blow time than the
fuse in the plug. Try plugging the washing machine into another ring main. Or
try plugging out all the other appliances on the same ring main and test it
out.
If the ELCB (Earth Leakage Circuit
Breaker) is tripping only when the washing machine is running then something in
the machine is faulty.
One common problem is the heating element. Over time they tend to crack and
when the water gets in, the ELCB will trip out. This can be problematic to
diagnose as offten the element will only trip after a period of heating. Bottom
line, if it is tripping the ELCB then it is dangerous and should be fixed
before any further use.
Please get back to us if you have
further query else please accept the suggestion.
Thank you for contacting fixya.com
