I have a Sansui Platinum Plus 27" T.V. and at the top of the screen there are 15 white lines about 3" down from the top
This is called vertical collapse and the most common cause is a failure of the vertical IC. If you can update this with the model number, I should be able to provide the part numbers and costs for the parts required to fix this. Also, if you intend to repair this yourself, please indicate thtat as well. The parts will cost around $20 or so.
Dan
