I have a Fisher & Paykel IW812 Intuitive Eco. The problem started by randomly flashing lights when turned on with no readable display on the LED. After switching on and off it eventually came right. Sometimes it beeps when checking water level and then says power cut and starts again. Occassionally it gets to the wash cycle and gets to 27 minutes and beeps and says power cut and keeps resuming from the 27 minute mark. Sometimes it goes all the way through the cycle with no problems. Any help will be much appreciated
Mine is doing this too. It will eventually make it through the cycle, but sometimes it restarts 10 times, lights flashing. Other times it goes just fine. My house is brand new and the wiring is just fine, it's the machine.Mine is doing this too. It will eventually make it through the cycle, but sometimes it restarts 10 times, lights flashing. Other times it goes just fine. My house is brand new and the wiring is just fine, it's the machine.
You can't post conmments that contain an email address.
Re: I have a Fisher & Paykel IW812 Intuitive Eco. The...
I had the power cut problem too. When I called the repairperson they blamed faulty wiring. I haven't tracked this down to see if this is actually the case.
The display screen clicks in.
Use a flat blade screwdriver to unclip the display.
Two low profile electrolytic capacitors need to be replaced,
Is a common problem in IW LCD display boards.
Hi just read your posting.Unless the machine shows an error code the diagnostic mode will not help.Does the machine agitate in the wash cycle?Does the machine drain the water completely?Does the machine spin the clothes dry.Please reply with additional information on the questions I have posted and I am sure I can help you rectify this fault.Looking forward to your reply.
