Swan sw2061w runs cycle then the end light and 60 wash lights flash continuous but door won't open?
This is normally a blockage in the pump / filter, or waste pipe, Turn the machine off, then put some towels on the floor, to catch waste water, then remove cover from bottom (or open hatch), behind is a knob, unscrew this and the water will run out, check for any obstructions in the know side and inside, if nothing, put back together and then, put the washing machine out, and check the waste pipe for blockages, pull the pipe out, look inside both pipes and if clear put back in. refit as was and then try machine again!
if it was this simple problem then you have just made a simple fix, pat yourself on the back.
should be able to restart the machine and it may start to run or set it to spin again and it should finish this time
Enjoy
One other thing is a bad load in the washing machine, normally when you have bulky items in like think blankets, that can not balance out the drum, if you have these items in there, try a slower spin speed, next time, with this type of load, wash without spinning.
If the same time to call an engineer!
