Question about Kitchen Appliances - Others
I need to find the user manual for a Hatchrite Mobel Number HR CP I-250 or HR MP I-250 incubator.
See my free Hatchrite information web site at
http://idk.serveftp.net/hatchrite/manual/
There are manuals available for download for the CP-50 and the Watlow controller that goes with this model. Hatchrite used the same hardware on many different models, so the CP-50 manual may give you a good start.
Best regards,
Kevin G. McCoy
Posted on May 10, 2012
6ya staff
SOURCE:
I need instructions for a janoel 12 egg incubator please i have lost mine
Here are instructions from another website along with various links to download manuals and lead you to other forums talking about egg incubators:
Operating steps:
1. Put the mesh with the rail(big mesh)(fig.1) into the incubator.
2. Put the moveable egg tray (fig.2) on the mesh with rail, please do it within the rail.
3. Put the egg tray grille ( fig.3) into moveable egg tray according to size of egg for incubation.
4. Put the hatching egg into moveable egg tray(fig.5) for incubation, pay attention that after each egg is put into the grille, there should be 5mm clearance at least for convenient turning of hatching egg, inject 100ml water into the base after the hatching egg is put, check once for every two days so that the incubator is not short of water. Every water injection shall not be more than 100ml, take down the date of placing hatching egg so as to well control the hatching time. It's best to place the incubator on 60-100cm for convenient insertion of link rod.
5. When closing the cover(fig.7) , the link rod must insert the shifting slot of moveable egg tray, so that the egg tray can shift normally.( in other words, the cercley thingy coming out of the top with a rod in it has to be attached to the egg tray by putting the rod into the egg turner square hole to make sure that the incubator turns the eggs well)
6. Switch on the power supply after closing the cover, and set temperature according to push-button instruction and incubation technology. If the user has no time to care about the temperature, the temperature can be set at 38'c from the first day of hatching, and it can be set as 37.5 - 37.8C since the following day of hatching.
7. It moves to hatching tray 3 days earlier than incubation period for other poultry
8. It usually takes 3-4 days less than the number of incubation days for egg tray replacement, replace the egg tray once one or two hatching eggs are seen hatched, take all of the hatching eggs off from the incubator firstly, then take the moveable egg tray with mesh with rail out, check the water level, then put the hatching mesh( fig. 10) and egg tray in and put the hatching egg on the egg tray, shown as fig. 11.
9. After closing the cover and switching on the power supply, the hatching situation can be observed.
This was originally posted here: Janoel 12 incubator help
Best wishes,
Joe
I’m happy to help further over the phone at https://www.6ya.com/expert/mark_7bbaa7a1174e0903
Aug 25, 2016 | Hard Computers & Internet
User manualfor bush dvrhs02
Here is a link to get a dvhrso2, don't know if this is the one you need or not?
http://3wires.net/manuals/BushHVRS02.pdf
Jan 26, 2016 | CP Technologies Time Lapse VCRs and DVRs...
I cannot fine a manual or user guide for the Casio HR-100TM Calculator
You can try this site to download a copy, however my McAfee blocked it when I tried to download it??????? You will try this at your own risk!
http://filesfromtheworld.net/casio-hr-100tm-user-manual/
Feb 23, 2015 | Casio HR 100TM Portable Printing...
How do control temp. On a vwr 2310 incubator
You can get assistance from Sheldon Labs
Email: support@sheldonmfg.com
Phone: 503-640-3000 ext. 2407
Feb 13, 2018 | VWR Sheldon 2310 Mini C02 Water Jacketed...
Does anyone have an instruction manual for the JN8-48 Egg Incubator?
http://www.backyardpoultry.com/forum3/download_vault/JN848%20user%20guide01.pdf
Mar 16, 2014 | Bird Inc Digital Egg Incubator Thermometer...
I need a user manual for a gallenkamp incubator inc200 model
I need user manual for Argis IO-1P TE Incubator for Chicken
Aug 07, 2011 | Ovens
How to set the date and time
You can set the date and time on the machine:
1) Press <Fax>
2) Press <Menu>
3) Use [<] or [>] to get to "User Settings"
4) Use the number keys to enter the date (only use the last two digits of the year) and time (in 24 hr format)
5) Press <OK>
6) Press <Stop/Reset>
Your MP 530 should obtain the time from your computer when hooked up with the MP driver installed.
Jan 14, 2010 | Canon PIXMA MP530 All-In-One InkJet...
To replace a bulb in the Hitachi CP-S235 LCD Projector, do I just unscrew the two screws under the plate underneath the machine? Are there any precautions I should take, like not handling the bulb? I have...
Yes to replace the lamp you need to remove the 2 screws. You can touch the lamp but I try not to. After the lamp is in you need to reset the hr timer for the lamp. to do this you need to look in manual on page 34.
If you do not have the manual you can get it here at link below.
http://www.aboutprojectors.com/pdf/hitachi-cp-s235-manual.pdf
Good luck
Oct 05, 2009 | Hitachi CP-S235 Multimedia Projector
???maximum user weight for Precor 9.45i
Normally most home treadmills are 250-300lb user capacity.
Call Precor with your model # and S/N and they can tell you exactly.
Apr 27, 2009 | Precor C956i Treadmills with HR /...
Manual for 3m mp 8730?
http://www.projectorcentral.com/pdf/projector_manual_386.pdf
your projector is the exact same as the hitachi cp-x950w/e. as a matter of fact, hitachi made the 3m mp8730.
Apr 26, 2009 | 3M MP 8730 Multimedia Projector
Kitchen Appliances - Others Logo
229 people viewed this question
Top Kitchen Appliances - Others Experts
Marvin
Marvin
Irene Tulloch
john h
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
