My dvd drive on my panasonic toughbook will not play dvd's, It reads them but will not play movies with any media software no matter what codec I use? It will read any data discs with no problem?
try to run the cd on another system. if the computer recognizes that
there's a cd in the drive, that may mean that your DVD Drive may be
going bad.
Usually DVD Drives dont fail all at once.
it happens gradually.
1st it stops playing some dvds, then it stops playing dvds altogether
Hi,it's obvious from your problem that the particular disc that cannot be viewed on your computer is of a formatt not supported by the windows XP.some DVDs are of low quality which can be viewed practically on any DVD player but as a result of their low quality and the sensitivity of the Windows they are not recognized by your computer.
In as much as other DVDS play on your computer,it means there's no problem with your computer,but an unsupported disc formatt is been trying to be viewed and there's nothing you can do to view a DVD formatt not supported by your computer.please don't be bothered.
Thanks and take care
1.use original disc, bcz some brand drives not supported all the discs available in the market.
2.cheak with other disc,if any disc cant read ,then
* Open Your CPU system cabinet,then cheak the data cable and power cable of the Dvd/Cd Drive.(You may change the other power card in your system already had)
* change the data cable
3.if u still have the problem,then finaly replace the new drive.LG Dvd Drive is beswt one.because it can read all discs.
A CD-Rom will only recognize CD's. It must be a DVD-ROM to recognize DVD's. DVD-ROM will recognize CD's ,but not the other way around. No drivers needed for thes, they are plug and play.
Does the computer immediately return the discs after they're inserted or do you have to manually eject them? If it's trying to read the discs then there could be a problem with the type of disc. However if it just ejects the disc immediately, there could be a recognition problem. So, if your computer doesn't recognize that a disc is in the drive, you can check several things. 1. Check to see that the computer actually reads DVDs. To do this, open the System Profiler in the Utilities folder. Click on ATA/Devices and Volumes/Disc Burning. Those are three different options but each will tell you if the drive actually does run DVDs. If it shows DVDRW or DVD, but if it only shows CD or CD-RW, then it won't play a DVD. 2. If it shows that it accepts DVDs through the System Profiler, then you'll need to check to see if the actual drive is attached. You can open your computer through the battery with a screw driver. Once open, you'll need to check the connecting cable to the drive. If it's attached properly/securely, you may need to take it to a technician. The drive me be malfunctioning and need professional repair.
you can try uninstalling the drive, by going to my computer, right click>properties>hardware tab>device manager and look down the list for cd/dvd drives, click on '+' sign and right click on your drive make and select uninstal.
Restart pc and your drive will be reinstalled automatically again.
If you have a cd cleaner disc run that also.
Try to run the game again, although it may still not work as the drives laser seems to be out of line or simply run it's life, and a new drive is the only answer i'm afraid.
the dvd drive don't recognize the cd
