There
can be many reasons why your dryer will not start or turn...
The
most common causes are the belt breaking or jumping off, or the motor
going bad...
Here are a couple of tips that I wrote will help
you to figure out why your dryer will not run...
Dryer Repair
- The Dryer
is not Turning
Dryer
Repair - The dryer
will not start
heatman101
SOURCE: Crosley dryer Cdes563sq0 if i turn the timer on
It sounds like there is a problem with the motor/belt. If you can get the top up, mine you have to push in two clips between the lid and the body about two inches in from the right and left sides, you can look down into the machine to see if the belt is still on track or if the motor is turning. I had one dryer that the belt would come off the spring tensioned idler pulley. Best of luck
