Modixerox 5510 functioning
I Have modixerox 5510 and it copy very light even if i maximise the darker button suggest me solution so that i get bright and darker copy.
    Scholar:
  • 53 Answers
Digital copiers will copy very light if the optics (mirrors, ccd lens) are dusty (opposite to the old analogue copiers which got darker) Clean whatever you can get at with a soft dry cloth.If it prints light from your computer then it won't be the optics, could be the ROS unit. If the ROS unit is dirty that's somewhat more complicated, the only bit you can get at is the ROS window, you'll have to pull the drum out and clean the glass window you can see from there
Posted on Jan 20, 2008
6ya staff
SOURCE:
How to make darker copies
if your referring to photocopying but printout is darker, it doesnt work. canon copiers produce copies like the original or better than the original sometimes. try to scan the file in custom mode and adjust the brightness and contrast and click preview to view the outcome before scanning it then print it later
Sep 30, 2013 | Canon PIXMA MP210 Photo All-In-One Printer
Our copier is copying in light shade. how to make it darker
To adjust the default lighter/darker setting
1. On the LaserJet 3015, press MENU/ENTER.
2. Use the < or the > button to select Copy setup, and then press MENU/ENTER.
3. Use the < or the > button to select Def. Light/Dark, and then press MENU/ENTER.
4. Use the < or the > button to adjust the setting. Move the slider to the left to make all of the
copies lighter than the original, or move the slider to the right to make all of the copies
darker than the original.
5. Press MENU/ENTER to save the selection.
Page 48 of the User Guide has instructions for adjusting the light/dark setting during a copy job.
Also see the Troubleshooting section of the User Guide for other possible reasons for light/faded copies.
If your copies continue to come out too light, you may need to clean the insert a new toner cartridge or change brands of toner. I tried several "generic" toner cartridges and refills, but my prints and copies were always faded or streaky. After going back to genuine HP cartridges, I haven't had any print quality problems.
Jul 21, 2011 | HP LaserJet 3015 All-In-One Printer
Lost my user's guide need to change make copies darker
May I know the model # of your machine?
Some of brother machine have the copy options where you can change the brightness, contrast and color of the document that you are copying.
For example for MFC-240:
You can change the brightness contrast by pressing copy mode. Then load the document in the feeder, press copy option so that it will show the option to change the brightness, contrast and color. Just press the arrow key to select the brightness then hit ok/menu. then press arrow key to have it lighter/darker..
Hope this helps.
Mar 29, 2011 | Brother Office Equipment & Supplies
5510 all in one, my fax has stopped working. I reinstalled the 5510, the wizard set up my fax, it rings, picks up, BUT doesn't do anything else. Try to send and it sounds like it doesn't dial out? It...
First, I would suggest suggest you reset the FAX. If resetting does not solve the problem, you can then read and follow instructions on this link; http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01669298&tmp_task=solveCategory&lc=en&dlc=en&cc=us&product=311255
1. Remove all of the paper loaded in the main input tray.
2. Press the power button to turn off the HP fax product.
3. Disconnect the USB cable from the back of the HP fax product.
4. Disconnect the power cord from the back of the HP fax product and from the electrical
outlet, and then wait one minute.
5. Reconnect the power cord to the electrical outlet.
6. Reconnect the power cord to the back of the HP fax product.
7. Press the power button to turn on the HP fax product.
8. Reconnect the USB cable to the back of the HP fax product.
9. Replace the paper in the main input tray.
10. Use the HP Fax Test Service to try to send and receive a fax.
Good luck.
Mar 24, 2011 | HP Officejet 5510 All-In-One Thermal...
I WANT TO COPY A DOCUMENT DARKER
There should be a menu item or button that allows you to adjust the copier's brightness or contrast. The icons may be represented as a circle with half-white, half-black center, or as a circle with lines surrounding it, like a sun.
It would help to know your model of copier, or at least your manufacturer.
Jun 21, 2009 | Office Equipment & Supplies
Ink tone
Hi Pam -
This is a common problem with the CX 5000 - there is no contrast control (i.e., light/dark) like you would have on a photocopier. But if you use the scanning mode (EpsonScan) instead of the copying mode, there are a couple of alternative options that might help:
1) Brightness - in the EpsonScan program, in Home Mode, under Image Adjustments, there is a button labelled "Brightness." Depending on the colors and contrast of what you're copying, adjusting the brightness may help.
2) Color Restoration - In both Home Mode and Professional Mode, this feature is meant to restore the color to a faded photo - depending on the colors of your document, it may make the copy lighter or darker, but it's an option.
Hope this helps!
Dec 11, 2008 | Epson Stylus CX5000 InkJet Photo Printer
My monitor is getting darker by the day. rigth now i can't even see some the things it ois showing on the screen. please what are the problems and solution. so also is my flash drive doesn't let me copy...
most monitors get darker with age -- for a while you can counter this by turning up the Brightness and Contrast controls, but this only gives you a little extra time (and probably speeds up the decay process anyway).
for copy file check this one-------> CopyFile API
Sep 16, 2008 | Computers & Internet
Copy Quality
open lid press copy is scanner bulb bright white if not bulb is burning out or has burnt out
Sep 08, 2008 | Lexmark X7170 All-In-One InkJet Printer
Indoor photos are too dark and skin tones orange-ish
I have the same problem at my church with the indoor lighting on my camera. I'm able to get it work by putting the whole thing on manual and adjusting the lighting settings that way.
Jun 13, 2008 | Sony Cyber-shot DSC-W70 Digital Camera
102 people viewed this question
jasbo
jasbo
Ekse
Marvin
Marvin
