Your owner's manual should tell you what type needles your machine uses. According to this site, 130/705 needles will work with your machine, are also very common, and are available in several brands: Schmetz, Janome, Organ, etc.
http://www.sewingpartsonline.com/necchi-6018-sewing-machine-parts.aspx
In addition, you will need to determine the needle sizes (60/8 through 120/19) as well as the needle point (universal, ball-point, sharp/microtex, top stitch, embroidery, leather...) so the needle is compatible with the thread and fabric you are stitching.
SCHMETZ Household Needle Chart
Be sure to change the needles frequently. A needle should be replaced about every 8 hours of sewing time. Sewists tend to skimp in this regard (although needles are the least expensive fix!), but the needle is the most frequent cause of sewing machine issues. So, if your machine begins to misbehave, the first thing to try is a brand new needle.
Thank you!! Couldn't get an answer at Sears.
