Check the network cable... disconnect the network cable and ping the copier... if you can get the copier IP address to respond... then you have an IP conflict... if you plug the network cable back in... turn the copier off and on and still cann't print from any pc... then reset the copier... if you still cannt print from any pc then you need to try changing the IP address... and try again... still doesn't work... change the network cable and try again... still doesn't work... plug a laptop into the network cable and ping the laptop... if the laptop works... the print card is bad...
I’m happy to assist further over the phone at https://www.6ya.com/expert/norman_d2fa496dce30c65d
If the installation screen does not appear:
In Windows 2000, double-click My Computer from your desktop.
error e0
733
