Casio Cassiopeia E-200 Pocket PC Logo
Posted on Dec 12, 2009
ROM in Casio E-200 appears to have been erased in updating
Attempted to update ROM in Casio E-200 to latest version via ActiveSync 4
and download completed but Pocket PC locked up during install and not device will not even power up
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Dec 12, 2009
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
86
Points
My phone wonk let me use my t-mobile sim card and its an vigin phone! help me please?
1helpful
Free maps downlolad
If/when you've just purchased a (brand) new TomTom GPS, you can register it (at the TomTom.com website) and download the latest map (for your device) .... free ... as part of the latest map guarantee.
Whenever you connect your GPS to the TomTom website (via TomTom HOME), you'll get (free) updates to your current map version - ... but they are NOT new versions of the maps.
To get new versions of your (current) map, you'll need to purchase the update (e.g. online, on the TomTom website). Upon paying for it, you will get the activation codes, etc. for you to download, validate and install the maps.
If your GPS has lifetime maps, (after you have registered), you'll be able to connect (via TomTom HOME) to get the latest map release, without requiring any code/password.
Jun 21, 2013 • Tomtom GPS
1helpful
I have an HTC 8925 and when I turn it on, it turns on but it doesn't fully load. The only thing it shows is the ATandT logo on a white background. It does not make any sound or beep or anything in that...
Thanks for visiting FixYa!
From your explanation, it sounds like you've downloaded an app or program that has a driver conflict with the phone's operating system. You may need to flash your phone's ROM (operating system) with a new updated version to get it to work properly again. Since you didn't include who your cellular carrier is, I'm going to assume that it is AT&T. If the phone is not an AT&T Branded phone, disregard these instructions.
This phone is also called the HTC Tilt 2 (AT&T) and there is a new ROM download for the phone which should solve your problem. You'll need to follow the directions EXACTLY to flash your phone's ROM - and I do mean exactly!
This software update is intended for the HTC Tilt 2 for AT&T only and users should not load or attempt to load this version on any other device as it may cause serious issues/damage.
Please note that during the update process, the device will be Hard Reset and anything that is NOT part of the Operating System (contacts, calendar, music, etc) will be permanently deleted; always make a point of backing up your device's data on a regular basis!
Before you proceed, please confirm that this software upgrade is a newer version than what is currently loaded on your device. If it is the same version and your device is operating normally, there is no need to reload the software.
To determine the software version running on your device, go to Start > Settings > System Folder > Device Information > Software Information.
Validate that the ROM version is 2.10.502.4 if it is not, you will need to update the software on you device.
Before you run the ROM Upgrade Utility (RUU), make sure you check and do the following first:
  • USB sync cable is connected to your device and PC to establish a connection with Activesync/Windows Mobile Device Center. If you don't have ActiveSync installed on your PC already, the CD found inside your handset box can be used to install the application. If you lost the disk, please go to www.microsoft.com >Downloads & Trials> Windows Mobile Downloads and download the appropriate application (ActiveSync or Windows Mobile Device Center) depending on your PC's OS. You will also need Outlook or Outlook express installed in order to backup your contacts, calendars, e-mail, tasks etc.
  • Remove your storage card prior to running the upgrade. Do not put it back into your phone until after the upgrade process is complete.
  • The standby and hibernation modes are disabled on the computer.
  • All running applications on the computer have been closed.
  • Ensure that you device has a battery level of at least 50% (Start > Settings > System Folder > Power > Battery) If the battery "dies" during the upgrade process, there is a chance that the device will not recover and will need to be sent to HTC for repair.
  • The update can take several minutes so set aside time when you will not be interrupted.
  • Do Not interrupt the upgrade process or press any buttons on the device until the process has been completed (the device will reset itself when the update is done).
  • Warning: Installing this update will erase all data stored on the device, restoring your device to the factory default settings. Please be sure to back up any important files to preserve your data.
General Procedure on Installing the ROM Update
  1. Back up your personal data from the Mobile Device to your computer using ActiveSync (Windows XP or sooner)/Windows Mobile Device Center (Windows Vista and Windows 7) or a 3rd party backup utility if you want to ensure you don't lose any of your data.
    • If using a 3rd party backup utility, be sure that you are not backing up the Registry as this will cause issues once restored to the device after the update.
    • You will need to reload any 3rd party applications manually. Once you have created your backup file, be sure to copy the backup file to a storage card (ensure that Storage Card Encryption has been disabled on the device if you have enabled it) or to your PC before proceeding with the ROM update.
  2. On your computer, click on the Download link (below) and save the file to your desktop.
  3. Establish a connection between ActiveSync/Windows Mobile Device Center and your device using the provided USB Data cable.
  4. Locate the ROM file (the one you saved in step 2 above) on your PC and double-click on the file to run the ROM Update Utility (RUU) to install the ROM update to your Mobile Device.
  5. Follow the RUU Wizard prompts. When presented with the readme screen, please read the Readme since it provides a lot of valuable information on the upgrade process and what you can expect during the upgrade process. Check the box beside the "I understand the caution indicated above and has reviewed the Readme" and then press Next to continue. The remaining steps will typically involve checking the check box and pressing the Next or Upgrade button until the upgrade is completed.
  6. Restore your personal data back to your Mobile Device using ActiveSync/Windows Mobile Device Center or the 3rd party backup utility you selected.
Click here:
HTC Tilt 2 (AT&T) ROM Update 2.10.502.4 ' 08.30.2010 then click on: Download when you get to the HTC Downloads page to download the ROM to your PC. Then begin the install.
Apr 07, 2011 • Cell Phones
MY HTC G1 STRUCK ON G1 SCREEN
when you stuck on g1 big screen, you need:
1. download the right g1 radio
2. download danger spl. be carefull with this, search in wikipedia about it
3. download the latest rom
4. copy all file (in zip) to micro memory
5. enter fast boot (home + power about 20 second)
6. updated files radio first, reboot
7. updated dangerspl, reboot
8. updated rom
9. do hard reset / wipe (alt w) via fast boot
all done
Dec 03, 2010 • HTC G1
Hi: My computer is not recognizing my ts-h492a
Please go here and download the live update from Samsung. This software is designed to automatically update you to the latest firmware via the internet. To get this service, customers have to install the Firmware LiveUpdate program on their computers.
Please download the live update full version if you have not used this software before. See link.
http://www.samsungodd.com/Eng/Firmware/liveupdate.asp
Simply follow the instructions as given and your software will be updated to the latest version required to run your CD/DVD writer with your computer.
Hope this helps. If so please do leave a vote for the solution. Thanks.
2helpful
2answers
I forgot the password to my ipod touch
There is only one way, you must restore the ipod which wipes out everything if you forgot it.
Updating and Restoring iPod touch Software
You can use iTunes to update or reinstall iPod touch software, restore default settings, and delete all data on iPod touch.
• If you update, the iPod touch software is updated. Your downloaded applications, settings, and data aren’t affected.
Note: In some cases, an update may also include restoring iPod touch.
• If you restore, the latest version of iPod touch software is reinstalled, settings are restored to their defaults, and data stored on iPod touch is deleted, including downloaded applications, songs, videos, contacts, photos, calendar information, and any other data. If you’ve backed up iPod touch with iTunes on your computer, you can restore data from the backup at the end of the restore process.
Deleted data is no longer accessible via the iPod touch user interface, but isn’t erased from your iPod touch. For information about erasing all content and settings, see “Resetting iPod touch” on page 122.
Update or restore iPod touch:
1 Make sure you have an Internet connection and have installed the latest version of iTunes from www.apple.com/itunes.
2 Connect iPod touch to your computer.
3 Select iPod touch in the iTunes sidebar and click the Summary tab.
4 Click “Check for Update.” iTunes tells you if there’s a newer version of the iPod touch software available.
5 Click Update to install the latest version of the software. Or click Restore to restore. Follow the onscreen instructions to complete the restore process.
For more information about updating and restoring iPod touch software, go
1helpful
2answers
Is there a free update for the garmin nuvi 200?
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Sorry, no free maps. I know I've tried. You either live with the old map or but the latest version.
I bought the life time maps updates and I'm glad I did.
I've updated my maps at least 6 times.
New maps are about $70.
Life time maps are about $99 (when I bought mine)
BUT FIRST make SURE you have the latest software in YOUR computer and in YOUR Garmin before you load any maps.
You can get that FREE at Garmin here:
Normal 0 false false false MicrosoftInternetExplorer4 To download the latest unit software visit Garmin website: www.garmin.com/webupdater
After installing WebUpdater once from the Garmin website, perform all future software updates from your computer. Simply connect your compatible Garmin device to your computer, then run WebUpdater from your computer's "Start Menu" by selecting "Start", "Programs", "Garmin", and finally "WebUpdater"
REMEMBER: It takes hours to do a complete a map update.
Unless you bought the Lifetime maps you may have to pay for current maps.
Does this help? Let us know. Thanks.
2answers
My ipod touch is locked and i forgot the passcode and its disabled and i cant link it up to itunes unless i unlock it which i cant
Updating and Restoring iPod touch Software You can use iTunes to update or reinstall iPod touch software, restore default settings, and delete all data on iPod touch. ââ If you update, the iPod touch software is updated but your downloaded applications, settings, and songs are not affected. ââ If you restore, the latest version of iPod touch software is reinstalled, default settings are restored, and data stored on iPod touch is deleted, including downloaded applications, songs, videos, contacts, photos, calendar information, and any other data. In iTunes 7.7, you can also restore from a backup without deleting data stored on iPod touch. Note: Deleted data is no longer accessible via the iPod touch user interface, but is not permanently erased from your iPod touch until it is overwritten by new data. For information about permanently erasing all content and settings, see “Resetting iPod touch” on page 94. Update or restore iPod touch: 1 Make sure you have an Internet connection and have installed the latest version of iTunes from www.apple.com/itunes. 2 Connect iPod touch to your computer. 3 Select iPod touch in the iTunes sidebar and click the Summary tab. 4 Click “Check for Update.” iTunes tells you if there’s a newer version of the iPod touch software available. 5 Click Update to install the latest version of the software. Or click Restore to restore. Follow the onscreen instructions to complete the restore process.
1helpful
2answers
30 gig iPod after plugged up to computer completely stopped working
you said its not responding to the reset trick nor turn on or charge, plug ipod to pc via usb plug. go to my computer find the ipod it shoudl show up as a hard drive. if it is there click on it and copy the ipod software to the pc (non music). now format the ipod (you was going to erase it any way) once formatted copy the ipod software from pc, back to ipod. this should make feel and act as new again. download and updated version of itunes and put your music onto ipod. feel free to rate this suggestion
I can't install a certain HP update.
1. Download the SoftPaq to a directory on your hard drive.
The file downloaded is a self-extracting executable with
a filename based on the SoftPaq Number above. 2. Establish an Activesync connection between your iPAQ Pocket
PC and host PC.
3. Execute the downloaded file and follow the on-screen instructions
to install the Real Time Update.
4. Follow the instructions to perform a normal reset on the iPAQ Pocket PC.
on step 3 you should see the setup on your pdas screen do you see this?
Waiting for your reply. :)
Updates
I have been using ActiveSync for several years now. From time to time I upgrade to the latest available version that I can find on the Microsoft website. I have been using version 3.8 for several months without major problems. So I can recommend for you to install version 3.8.
Top Casio Computers & Internet Experts
k24674
ZJ Limited
ZJ Limited
Are you a Casio Computer and Internet Expert? Answer questions, earn points and help others
