I just bought an Ilo TV and I need the remote code to program my Direct TV's remote to work the satelite box and the TV. There is no code in the Direct TV's manual for the Ilo TV. Can you help me ???
I need the remote code to program my Direct TV's remote to work with a satellite box and a TV. I tried program it by using Emerson codes with no success. I need the remote code to program my Direct TV's remote to
with no success.
with no success.
I have an Innovage Jumbo remote . I am trying to program it to a ILO 27" LCD tv
, but cannot come up with the right code. Please help!I have an Innovage Jumbo remote . I am trying to program it to a ILO 27" LCD tv
I need the codes for my direct tv remote so that i can use it on both the tv and the dtv reciever. please help... johnI need the codes for my direct tv remote so that i can use it on both the tv and the dtv reciever. please help... john
me too, my remote even stopped working. So I want to use a universal, but no luck even on self find option on remote. dwh ------ Although I've had mine for over a year now using it as a monitor/tv in my office and still works great manually. dwhme too, my remote even stopped working. So I want to use a universal, but no luck even on self find option on remote. dwh ------ Although I've had mine for over a year now using it as a monitor/tv in my office and still works great manually. dwh
AnonymousMar 21, 2014
I need the codes to program a RCA remote to a ILO tvI need the codes to program a RCA remote to a ILO tv
You can't post conmments that contain an email address.
Press menu and go to settings. select remote, code search and follow the on screen instructions it may take a few minutes to locate the correct code but it is in there.
the installer told us that the remote could not be programed to our ILO tv, he was wrong I made it happen without any trouble.
I had the same problem with my ILO tv, I found a code for Funai- manufactured by the same company. Unfortunatly I don't know the codes anymore, but I hope it helps.
Checked on line for any code there was that someone used for iLo t.v.'s, found two codes on your site that someone had used & used those & one of them worked. Thanks again!
I had the same problem trying to program my satellite remote to work with the ILO tv. I found that the emerson codes DO work. Yes local cable remotes will work as long as you have the code and the brand is getting more popular. The code that worked with both cable companys, Charter and DirecTv was 10171 I believe. You can find it under the Emerson codes. Hope this was helpful.
Ilo is made by Orion and/or Sansui.
My Ilo dtv2794B was programmed on Direct TV remote as follows:
In Direct TV mode press 'menu' .
Go to parental ,faves setup
Go to system set up
Go to remote
Go to TV
Select brand (Orion)
Follow directions from this point.
Good Luck>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>
with no success.
with no success.
Try changhong coe #10765 worked for me...
i need a three digit code
yes same problem I can get the brand and neither the code for my ilo tv
need to program my direct tv remote
