Ricoh Aficio CL7000 Laser Printer Logo
Posted on Dec 13, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My ricoh printer is showinf an error of sc440-2
My ricoh printer is showing an error of sc440-2 and won run can tell me what this problem is?
gggg
Level 3:
  • Master 904 Answers
  • Posted on Sep 17, 2010
gggg
Master
Level 3:
Answers
904
Questions
Helped
520660
Points
1791
Sc440 on the CL7000 is a drum motor error. sc440-2 is specific to the color drum motor. The problem is either the motor itself, the drum gear position sensor, or one or more of the color photoconductor units. The photoconductor units you can replace yourself if you have extras -- see if that will clear up the problem.
If they don't, you'll need to contact a service technician to inspect (and replace if need be) the motor and sensor.
Please rate this solution if it was helpful. Thanks!
2answers
How to Fix Error Code SC899 on Ricoh Printer?
Steps to Fix Ricoh Printer Error Code SC899:- Start with unplugging the Ricoh printer network cable. Next, enter the service mode. Press the buttons in order as given after, [Reset] https://www.youtube.com/watch?v=ol2FUcWg08k
Hi, I have an gestetner ricoh mp2000 printer. and It shows this error out of toner. follow instructions. inside and replace toner.
http://www.fixya.com/answer/answerpageslideview.aspx?thid=27069781&ctg=459&brd=299
HiI have mp2000 ricoh printer It shows this error out of toner what should...
Ricoh printer installation error code scanner carriage error
same error after running this fix. It does list my printer in "searching for available printers", but when I choose the printer & click next, I still get "cannot connect to printer" & details shows "operation failed with error 0x0000000a."s
CBR Tech Solutions or http://www.cbrtechsolutions.com
My printer ricoh 2045 show an error sc 302,not print image correct
i have an error on my printer sc 302 how i can clear it easily .printer is ricoh 3045
3helpful
Ricoh SP C811DN error sc549
unplug printer, wait minute, plug in, should reset.
check Ricoh website to trouble shoot if does not reset.
1helpful
Error sc 547
Found this from:
http://slayo.com/ricoh-cl4000dn-error-code-sc542.html
Ricoh CL4000DN Error Code SC542
Turns out error SC542 indicates a fuser temperature problem. Once the error is detected, the printer is toast until you manually clear the error from the keypad. Even though the printer is physically fine, it won’t come ready until the prior error condition is cleared.
A few phone calls with our local Ricoh service rep, and he admitted that the printer might trip this error in a power brownout.
The printer was less than 30 days old and the error was caused by the brownout or the fuser failed. I kept calling the Ricoh rep, and they finally gave me the magic keystrokes over the phone.
I did the magic keystrokes, cleared the error code, and the printer worked fine. It’s been working great for a year now.
I hope someone else who has this problem finds this page and is able to fix the problem also. I didn’t find any help on the net when I searched.
The Fix In order to clear error SC542, you must perform procedure 5810.
  • Press and hold online + escape, then power on.
  • Use up and down arrow keys to select SP2
  • Press Enter
  • Use up and down arror to locate SP5
  • Press Enter
  • Use up and down arrow keys to select 810
  • Press Enter
  • Confirm the selection
  • Power off and on.
The error code is now cleared.
Hope this helps!
WizardRepair
Ricoh CL2000 SC486
it is the problem your cartridge sensor chip.You change cartridge unite & buy new cartridge than solve it
2helpful
3answers
Printer shows error CH551
Is this actually a Ricoh Aficio 1013F, or another model, because "CH551" is not a ricoh service code?Do you mean "SC551"
If so, this is a fuser "triac" problem (basically a fuse in the heater unit). It can only be reset in service mode after the problem is fixed...and will require a tech.
44helpful
4answers
Function sc:552 problem RICOH AFICIO 2018d
To reset error, enter SP mode by pressing: Clear (yellow) button, 1 0 7, and press and hold the Stop (orange) button for 3 seconds then switch off and on the copier.
If the error is still there, please check the following in the fuser unit;
  • Check and clean or replace the possible defective thermistors or out of position.
  • Fusing heaters open circuit.
  • Thermostats for open circuit.
  • Power supply unit.
Good luck and please rate me, thanks.
Top Ricoh Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
