Side By side. ED2FHEXMQ00. Will not Cool. Compressor clicks to start, runs for 15-30 seconds, then clicks off. Will Cycle this way yet no cooling. Fan is good, Coils are cleaned and setting at mid point on both freezer and fridge side. Prior to loosing all temp from fridge, could hear the thermostat click in at current temp as adjusting. Is overload or capacitor a problem on compressor. Compressor does get hot as it cycles. Let it cool and back to start, stop. with no temp change. Thanks for any assistance.
SOURCE: fridge not cooling
Most of the time on a whirlpool the problem is the relay on the compressor sometimes called the start device. I would replace that first. If you need help finding the part let me know. I will need the complete model # from the sticker inside the fridge section. You can look it up with diagrams at http://www3.sears.com/.
SOURCE: GE frost-free refrigerator
well you need to know when it was manufacture if it lands under the 5 years seal system warranty then it can be fix for free. on the other hand be sure that compressor is running because if it is not it could be a relay and that is a cheap fix
SOURCE: The starter/overload and overload protector
The easiest way to find this out , is to check the condenser. Make sure that the condenser is not clogged up with dust and that the condenser fan is working. Replace the start relay. Turn it back on. If it starts right up then it probably overheated and melted the relay due to the condenser fan not working or the condenser clogged with dust. Air circulation through the condenser and air being circulated over the compressor in how it cools itself. If the compressor will not start or if it runs for a little while and then shuts off from overheating, then you have a bad compressor.
SOURCE: replacing overload relay/capacitor on compressor of maytag fridge
replacing a start relay is very easy to do. usually its a swap the part wire for wire operation. in some cases you get a different looking relay but they normally have good instructions for the replacement part. if you'll post the model numebr fo your unit i can give you detailed instructions. thanks peyton
SOURCE: Whirlpool side by side does not cool at all
Simple Fix. That's cost around $40. You need to replace your relay/overload. Its mounted on the compressor. It should have a black box over it. Take it off then pull the part off the compressor and replace it with a new one.
