Press TOOLS (The spanner icon on the bottom right corner of the page with WHERE TO and VIEW MAP) I know this might take a little trial and error since it's in Spanish but should be possible.
Press SETTINGS (the spanner icon).
Press LANGUAGE (The lips icon)
This brings you to a screen with 3 items; VOICE, TEXT LANGUAGE and KEYBOARD To change the voice prompts to English press VOICE and select an English voice. To change the text to English press TEXT and select English or American English if you're in the USA If you press the KEYBOARD icon also select English
Press TOOLS (The spanner symbol in the right bottom corner of the screen that shows WHERE TO and VIEW MAP)
Press SETTINGS (The spanner symbol) or LOCALE (the blue symbol) on models that don't have a SETTINGS symbol.
Press LANGUAGE (The lips symbol)
This takes you to a screen with 3 items; VOICE, TEXT LANGUAGE and KEYBOARD Press each in turn. The VOICE will give you the option to select a voice by name and country. Select one that's from an English speaking country to get the voice prompts in English.
Press TEXT LANGUAGE and select English or American English if you're in the USA.
Press KEYBOARD and Select English. This should solve your problem.
Hello, you should be able to achieve this by resetting the GPS since its default is English.
Performing a Standard Reset
1. Slide the power switch all the way to the left (with the Nuvi's screen facing you). 2. Hold the switch in the position for at least eight seconds. 3. Push the switch to the right to power the Nuvi back on.
Performing a Factory Reset
1. Turn your Nuvi off by sliding the power switch to the left. 2. Press your finger against the bottom right corner of the touchscreen. Hold your finger in this position. 3. Slide the power switch to the right to turn the Nuvi back on. Continue to hold you finger against the screen until you see the factory reset prompt. Tap "Yes" to perform the factory reset.
This may be a result of a previous software
version on a device or possibly some one changing the settings. If a device
does power on with a foreign language that you can not understand it can be
corrected by going through the settings to change the text language. To change the text language:
Touch Wrench icon
on the screen with the Magnifying Glass and Map icon
Touch the Gears
icon
Touch the down arrow
Touch the second
option from the top1
Touch the middle blue
box on right
Touch the up arrow
until American English appears2
Touch American
English
Touch OK
Touch Back
The device should be in selected text language. Note 1 - In some cases, if there are Custom POIs
loaded to the device then it may be the first option at the top. Note 2 - If American English is not the language
needed, please selected the desired language
Hit Tools (wrench icon)
Hit Settings (wrench icon)
Hit Language (lips icon)
Hit Text (top bar on right) Change to English
Hit Voice (top bar on left) Change to English
my garmin 255 shows chinese language. How i can change to english?
Hit Tools (wrench icon) Hit Settings (wrench icon) Hit Language (lips icon) Hit Text (top bar on right) Change to English Hit Voice (top bar on left) Change to English
