I changed the large nylon gear in my opener the worm gear was ok, now the door will open but will not close unless the wall button is held down, I have not had any problems with the sensors prior to installing the large nylon gear, the opener clicks 10 tines when the malfunction occurs please advise
The opener clicking 10 times when the door reverses is a door sensor problem. You may have knocked a wire loose on the back of the motor unit or accidently bumped one of your door sensors. Make sure the small light on each sensor is lit and not flickering. Tweak them a bit to get them properly pointed at one another.
