Question about Hoover Nextra HNT 2135 Top Load Washer
Washing machine not draining properly?
My hoover nextra washing maching is not draining properly, so the clothes are still soaked when i get it out....any solutions?????
    Sergeant:
    Champion:
  • 353 Answers
Check and clean pump and or filter
Posted on Dec 15, 2009
Anonymous
SOURCE:
Hoover Nextra HNF2127 washing machine. Lights flashing at finish
Hi
Thanks for using FixYa. The start and pre-wash usually flash due to a clogged drain hose or the water pump. You’ll need to drain the water out of the base and also check to see if there's something stuck inside the pump or the drain hose connected to the pump (pump is usually located at the bottom and towards the back of the washing machine). If the drain line isn't clogged, you may have a problem with the water pump such as a frozen pulley or a broken impeller. If that's the case replace the water pump. Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Feb 18, 2010 | Hoover Nextra HNF 2137 Front Load Washer
Machine not taking the last fastest spin to drain the water.
the problem is that your machine is not emptying the water fast enough as the machine takes in a good deal more water on the rinse. clean the filter.
Feb 02, 2010 | Hoover Nextra HNWL 3126 Front Load Washer...
Hoover nextra washing machin3e , not draining
Yes Disconnect drain hose from the rear of washer. You will need to use special pliers that have notches in them to grab the hose clamp or you might need a Screw Driver if the hose clamp is a regular hose clamp. Remove clamp and flush washer hose with a high pressure hose or garden hose. Inspect drain where you took the hose off for any blockage. You might have to do this two or three times.Yet most of the time one time is good enougg. Good Luck!
Aug 28, 2009 | Washing Machines
Water not draing away and machine is not spinning
Empty your machine manually by lowering the drain hose into a bowl or bucket. Then remove the kick plate and check the filter for blockages.Before replacing try the machine on drain to see if the pump is running, if problem persists there may be a blockage in the pipe from the drum to the pump.
Nov 15, 2008 | Hoover Nextra HNWL 3136 Front Load Washer...
All washing just smell worse when washed
there is water laying flat somewhere that will not drain completely. thoroughly check the drain hose in the back...any kinks?
Jun 07, 2007 | Hoover Nextra HNF 2137 Front Load Washer
Draining & Spinning
I had a problem and when they took the back off. Underwire bra had got jammed through drum holes which stopped it spinning and water issues. I hope this might help.
Dec 17, 2006 | Hoover Nextra HNF 2137 Front Load Washer
Hoover Nextra HNT 2135 Top Load Washer Logo
417 people viewed this question
Top Hoover Washing Machines Experts
peter gittos
peter gittos
Gerry Harvey
Gerry Harvey
Poppa Maddo
Poppa Maddo
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
