Toshiba 56HMX195 52" HDTV DLP Projection TV Logo
Posted on Dec 14, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Tv turns on and off 3 times before picture appears
I just replaced the bulb in this tv 4 months ago. Now when I press the power button, the tv turns on and off 3 times before the picture appears. The red power light stays on, but a green light blinks. Any help would be greatly appreciated.
Anonymous
Level 2:
Guru:
  • Expert 114 Answers
  • Posted on Mar 24, 2010
Anonymous
Expert
Level 2:
Guru:
Answers
114
Questions
0
Helped
73282
Points
239
Have you Reset your Lamp?
every time that you change the lamp you need to reset and start a new count..
Anonymous
Level 3:
  • Toshiba Master 5,138 Answers
  • Posted on Dec 14, 2009
Anonymous
Toshiba Master
Level 3:
Answers
5138
Questions
5
Helped
1004393
Points
13534
Ballast Board its what turns Lamp on Call Encompass or visit their website. 1-800-638-3328
Samsung startup problem
serial number on 6.17.8.1
TV turns on, hear sound but no picture. Bulb isn't coming on. TV goes off after about 2-3 minutes. Bulb was just replaced 5 months ago.
Need the model number of the set and also if any lights on the TV come on or blink when the picture goes out or not.
I have a Panasonic PT-52LCX66 television that I bought just over 4 years ago. I have replaced the bulb for the second time just 3 months ago and now the set will just shut off after about 3 minutes of...
Tv making and have clicking sounds as tv shutdown as lights flashes?Yes.The board that call the Ballast board might be dying and dead soon.This Ballast board job responsible only are to ingnite the tv projection lamp only.
2helpful
2answers
Still getting "Projection lamp is nearing end of life"
KDF46E2000 - Change Lamp Warning - Reset
Bulb is most likely OK. Original bulb in Sony TV is Philips, label on bulb usually says Philips. Sony don't make bulbs. Sony Cost is usually 1.5 times other sources. Many shopping cart operations sell condemned, reject or poor quality electronic service items because cost of return and fooling with them is excessive. This is obvious and widespread with convergence ICs and other parts.
Lamp timer needs reset. This is usually an automatic function. TV detects Increased lamp current from previous failed bulb or weak bulb condition and resets automatically. TV must be unplugged for lamp replacement for this to work. Occasionally it must be reset manually, as below:
1. TV must be in standby mode. (Power off).
2. Press the following buttons on the Remote Commander within a
second of each other:
DISPLAY Channel 5 Volume + POWER .1. Access Service Adjustment Mode and select the Service Menu that
contains the Category with the Adjustment Item you want to change.
2. To change the Category, press 2 or 5 on the Remote Commander.
Note: Pressing 2 or 5 only changes the categories within the
Service Menu displayed. To change a Category on one of the other
Service Menus, press the JUMP button until the correct Service
Menu is displayed.
3. To change the Adjustment Item, press 1 or 4 on the Remote
Commander.
4. To change the Data Value, press 3 or 6 on the Remote
Commander.
Note: To go back to the last saved Data Value, press 0 then ENT
on the Remote Commander to read the memory.
5. To save the changes, press MUTING then ENT to write into
memory.
6. To exit service mode, turn the power off by pressing POWER .
Wait 2 minutes before restarting the set to allow the fans to
completely shut down or the Service Menu will appear on the screen.
easyab
ConvergenceRepair.com
__________________
1helpful
Tv turns on w/pic then pic dissapears light blinks 4 times
I have the same issue, we've had to change our bulb three times in less than two years. now we have 61" expensive paper weight. Our current bulb is less than 6 months old. The TV is only 2 years old and like i said this is our third bulb.
the blue light blinks 4 times. you get sound. then a few minutes the the picture returns... then it goes out, and the cycle goes on.
A solution to this would be greatly appreciated.
2helpful
Power light flashed red 4 times then repeats no pic,new bulb/fan!
Check the fan that cools the bulb. It is directly behing the bulb. It should turn on when the power comes on. It apparently has a safety to protect your tv(and home). mine is in the process of going out. looking for online solutions as we speak.
95helpful
2answers
I turn on the T.V. and the blue light is blinking and the T.V. doesn't turn on
1. simultaneoulsy press and hold [menu] and [vol-] on TV side panel
2. press and release [power] on TV side panel
3. count to 5 and release[menu] and [vol-]
4. TV should have turned on
5. if not, unplug TV and press[power]
6. repeat from step 1 if the TV does not power on the 2nd time
4helpful
2answers
Replaced bulb on PT50LC13 5 months ago. Now a box pops up when I turn the tv on saying to reset the timer. How?
1. MAKE SURE POWER CORD IS PLUGGED IN.
2. WHILE PRESSING THE VOLUME BUTTON ON THE PROJECTION DISPLAY,HOLD DOWN PIP0R SPLIT BUTTON ON THE REMOTE CONTROL AT THE SAME TIME FOR MORE THAN 5 SECONDS.
3. WHEN THE RESET IS COMPLETE, THE SCREEN ON THE RIGHT WILL APPEAR AND IT SHOULD SAY "LAMP TIME RESET TO "0"
5helpful
2answers
Reseting the lamp meter on tv
1) Press the POWER button to turn your TV on. Make sure you are set to Cable/TV reception. If the "replace lamp. Reset Lamp timer" notice appears, press "EXIT" on your remote.
2) Press and hold the VOLUME DOWN BUTTON on the TV set (not the remote, the actual TV set)
3) Continue to press and hold the VOLUME DOWN button and press and hold the PIP (Picture in Picture) or SPLIT/PLAY button on your REMOTE control (your are pressing and holding BOTH of these buttons at the same time now).
4) After 5 or 10 seconds (be patient), the lamp serice menu will appear and say your lamp counter has been rest to '0' (zero). That's it, you are all done.
Now, I continue to have the power shut off after a few minutes of play. I think it is a problem with the cooling fan. Damn it all anyway.
Top Toshiba Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
