try to remove your memory card and try to open it again..Most of the time memory card is the cause of hard starting, reason is the the card is not inserted correctly.
If you go to your network store (the closest to you) they should be able to help a small bit, Ive never come across this problem though so sorry if this doesnt work
1. Delete unused names/numbers from the address book to free up memory. (Perhaps write down the ones you want to keep for later re-entry)
2. Once a critical threshold is reached the msg inbox indicator will blink on
3. Enter inbox and DELETE as many messages as you can before phone freezes up again
4. If phone freezes or you get the error message again, restart and keep deleting from the phone book until it allows you hassle-free msg inbox access as per normal (but don't forget to continue deleting thos messages).
If your memory card is not working properly, back up any data from your device's memory card to your PC, then format the memory card using your Nokia device. Please refer to your device's user guide for information on formatting the memory card.
If you get an error message during the formatting process, or an error message after formatting stating that your device cannot read the memory card volume, please take the memory card to your nearest Nokia service point. Warning: Formatting your memory card will permanently erase all data stored on the memory card. Please back up all data stored on your memory card before formatting. Important: The memory card inside your Nokia device should ONLY be formatted using your Nokia device. Do not attempt to format your memory card on another device such as a PC, otherwise your memory card may not work properly.
Try removing your memory card and then using the phone.
If this solves the problem, then might be your phone is unable to deal with the amount of data stored on your memory card.
OR
Remove applications like 'FS caller' and applications that eat resources of your phone.
