I NEED THE SPEAKER CONNECTOR TO CONNECT THE RIGHT AND LAFT SPEAKE
I NEED THE SPEAKER CONNECTOR TO CONNECT THE RIGHT AND LEFT SPEAKERS TOGETHER FOR SONY MODEL SA-VA1
SEND FEED BACK TO MY E-MAIL ADDRESS- [email protected]
Enter your model number in the search box - Donot go by the pictures a few look the same but will not fit.Enter your model number in the search box - Donot go by the pictures a few look the same but will not fit.
You can't post conmments that contain an email address.
I guess you have tried switching the speaks left to right to check its the speaker rather than the output to the speaker?
If you have it might be worth (If you are able to) opening up the speaker unit to check the wires are still attached and solid, maybe need a little re-solder is needed as the wires are usually very thin.
The four speakers are split into two groups left and right. You connect the positive terminal on the upper left speaker to the positive terminal on on the bottom left speaker. Then repeat process connecting negative to negative on the same two left speakers. Then connect one wire from the upper left positive to the positive connector on the jack that is marked 4ohm LEFT on the plate attached to the rear of the speaker cab. The do the same connecting a wire from the negative terminal to the negative terminal on the same left jack. Now repeat the process on the right side in exactly the same way this time connecting to the 4ohm RIGHT jack. The switch that is in-between the two jacks can be set for either channel or for both together for stereo at 8 ohms HOPE THIS HELPS
hi,
You have to check the ohms of the speakers all spekers should be 8 Ohms or above. if not it will overload the amplifier at high level. The minium ohms impedence of the amplifier is 4 ohms. If you connect two 8 ohms speakers together then the effective ohms will be 4 OHMS then the amp will handle the speakers. If you connect two 4 ohms spekers together then the effective ohms will be 2 Ohms, this will overload the amplifier. You will be able to connect two 8 ohms speaker to left channel or right channel of the amplifier. Check the speaker spesifiction to know its ohms. Make sure all the speakers have an impedence of 8 OHMS or above
OK
A Right Front Speaker (+) Green Gray
B Left Front Speaker (+) Pink White
C +12 Volt Ignition Wire Gray Red
A B C D K L
D +12 Volt Battery Wire Blue w/ Yellow Stripe Yellow
E Right Front Speaker (-) Blue Gray w/ Black Stripe
E F G H I J M N O P
F Left Front Speaker (-) Purple White w/ Black Stripe
G Ground Wire Black Black
H Power Antenna Wire 1 Blue (join wires 1 & 2
I Power Antenna Wire 2 together to this blue wire)
AS VIEWED FROM MATING END OF CONNECTOR
Do Not Use
J
K Right Rear Speaker (+) Red Purple
L Left Rear Speaker (+) Black Green
M Right Rear Speaker (-) White Purple w/ Black Stripe
Do Not Use
N
Do Not Use
O
P Left Rear Speaker (-) Yellow Green w/ Black Stripe
1994 Jeep Grand Cherokee Car Radio Stereo Audio Wiring Diagram Car Radio Battery Constant 12v+ Wire: Pink Car Radio Accessory Switched 12v+ Wire: Violet/White Car Radio Ground Wire: Black Car Radio Illumination Wire: Orange/Black Car Stereo Dimmer Wire: Green/Red Car Stereo Antenna Trigger: N/A Car Stereo Amp Trigger Wire: N/A Car Stereo Amplifier Location: N/A Car Audio Front Speakers Size: N/A Car Audio Front Speakers Location: N/A Left Front Speaker Positive Wire (+): Green Left Front Speaker Negative Wire (-): Brown/Red Right Front Speaker Positive Wire (+): Violet Right Front Speaker Negative Wire (-): Blue/Red Car Audio Rear Speakers Size: N/A Car Audio Rear Speakers Location: N/A Left Rear Speaker Positive Wire (+): Brown/Yellow Left Rear Speaker Negative Wire (-): Brown/Blue Right Rear Speaker Positive Wire (+): Blue/White Right Rear Speaker Negative Wire (-): Blue/Orange Thank you for using Fixya and good luck
Under the center console/dash you should has two connectors.
LARGER CONNECTOR
A Right Front Speaker (+) Green Gray B Left Front Speaker (+) Pink White C Right Front Speaker (-) Blue Gray w/ Black Stripe D Left Front Speaker (-) Purple White w/ Black Stripe E Ground Wire Black Black F +12 Volt Ignition Wire Gray Red G Power Antenna Wire 1 Blue (join wires 1 & 2 H Power Antenna Wire 2 together to this blue wire) I Do Not Use
SMALLER CONNECTOR
J Right Rear Speaker (+) Red Purple K Right Rear Speaker (-) White Purple w/ Black Stripe L +12 Volt Battery Wire Blue w/ Yellow Stripe Yellow M Left Rear Speaker (+) Black Green N Left Rear Speaker (-) Yellow Green w/ Black Stripe
Typically, the LEFT speaker connects only to the RIGHT speaker.
The RIGHT speaker connects to the LEFT speaker.
The RIGHT speaker connects to the AC power-supply.
The RIGHT speaker connects to the "green" port (not the nearby "blue" nor "pink" connectors) on the "back" of your computer.
you can.. im guessing your trying to do that to "bridge" the amp to put out more watts.... you can do that but it puts a lot of strain on the amp that is pushing the speakers..(the radio)
1992 Saturn SL2 Car Stereo Radio Wiring Diagram
Car Radio Constant 12V+ Wire: Orange Car Radio Ignition Switched 12V+ Wire: Yellow Car Radio Ground Wire: Black Car Stereo Illumination Wire: Gray Car Stereo Dimmer Wire: Brown Car Stereo Antenna Trigger Wire: N/A Car Stereo Amplifier Trigger Wire: N/A Front Speakers Size: 6 1/2′ Front Speakers Location: Doors Left Front Speaker Wire (+): Tan Left Front Speaker Wire (-): Gray Right Front Speaker Wire (+): Light Green Right Front Speaker Wire (-): Dark Green Rear Speakers Size: 6 1/2′ Rear Speakers Location: Rear Deck Left Rear Speaker Wire (+): Brown Left Rear Speaker Wire (-): Yellow Right Rear Speaker Wire (+): Dark Blue Right Rear Speaker Wire (-): Light Blue
