Remove the water pump access plate from the front cover.
Remove the right hand fender liner.
Important: A drain plug has been provided at the bottom of the water pump assembly for additional coolant drainage from the engine block and water pump.
Drain the coolant from the water pump using the plug at the bottom of the pump.
mportant: The water pump holding tool supports the sprocket and chain during water pump service. The tool must be used or the balance shaft must be re-timed.
Install the J 43651 into position.
Tighten the bolts on the water pump holding tool into the threads on the water pump sprocket.
Install the access cover bolts that were removed earlier to secure the water pump holding tool to the front cover assembly.
Remove the 3 inner water pump sprocket to water pump blots.
Important: Be sure to remove both water pump bolts from the front of the engine block.
Remove the 2 water pump bolts. Remove the rear 2 water pump bolts.
Remove the water pump.
Remove and discard the water pump O-ring seal.
Installation Procedure
Important: Prior to installing the water pump, read the entire procedure. This will help avoid balance shaft chain re-timing and ensure proper sealing.
Install a NEW water pump O-ring seal.
Important: A guide pin can be created to aid in water pump alignment. Use a M 6 m x 6 mm stud. Thread the pin into the water pump sprocket.
Using the guide pin, align the pin with the water pump holding tool.
Position the water pump against the engine block and hand tighten the water pump bolts.
Notice: Refer to Fastener Notice.
Install the inner water pump sprocket bolts. After 2 are snug, remove the guide pin and install the 3rd bolt. Tighten the bolts to 25 Nm (18 ft. lbs.).
Tighten the water pump sprocket bolts last. Tighten the bolts to 10 Nm (89 inch lbs.).
Remove the J 43651.
Install the water pump access plate and bolts. Tighten the bolts to 10 Nm (89 inch lbs.).
no, here is the procedure. Please let me know if you have more questions.
REMOVAL & INSTALLATION
2.2L Engine
Remove the serpentine belt and tensioner.
Although not absolutely necessary, removal of the right front inner
fender splash shield will facilitate access to the front cover.
Install a suitable engine support fixture.
Remove the engine mount assembly.
Remove the alternator rear brace, then remove the alternator.
Remove the power steering pump, then position it aside with the lines still attached.
Raise and safely support the vehicle.
Remove the front two oil pan bolts.
Remove the crankshaft pulley.
Unfasten the front cover-to-block bolts and then remove the front
cover. If the front cover is difficult to remove, use a plastic mallet
to carefully loosen the cover.
Hi, there is a round cover on the front left corner. Install a pick in the small hole and turn the cover. You will see a twist cap behind the cover. Unscrew the cap and remove what ever is blocking the pump from turning. Watch out because the water in the tub will drain out.
Water pump is driven by timing chain idler and is mounted on the rear of the timing chain housing. Disconnect the neg. battery cable. Drain cooling system. Disconnect oxygen sensor connector.
Remove upper exhaust manifould heat sheild. Remove exhaust manifold brace. Remove lower exhaust manifold heat sheild. Loosen manifold to exhaust manifold spring loaded nuts. Remove radiator outlet pipe to water pump coverbolts. Disconnect exhaust pipe from manifold.
Pull down on the exhaust pipe to disconnect it from exhaust manifold bolts. Disconnect outlet pipe from oil pan and transaxle. If equipped with manual tranaxle, remove exhaust maifold brace. Leave lower radiator hose attached and pull down on radiator out look pipe to disengauge from water pump. Leave outlet pipe hanging.
Lower vehicle. Remove exhaustmanifold to cylinder head nuts. Remove exhaust manifold to cylinder head nuts. Remove manifould. Remove timing chain front cover. Remove timing chain tensioner. Remove bolts bolts securing water pump cover to cylinder block. Remove water pump to timing chain housing nuts. Remove water pump attaching nuts. Remove water pump and cover assembly. Separate componets as necessary.
WHEN INSTALLING WATER PUMP MAKE SURE YOU FOLLOW THE TIGHTENING SEQUENCES THAT AFFECT SEALING. My frist one I messed up and broke the pump so becarful.
Installation
If cover was separated from body during removal, join this componets with a new gasket and hand tighten bolts. Apply bearing grease to splines of water pump drive. Set body and assemble into position.
Install and hand tighten bolts securing cover to cylinder block. Install and hand tighten bolts securing cover to cylinder block. Installand hand tighten nuts securing body to timing chain housing. Lubracate outlet pipe "O" ring with antifreeze. (I use RTV) Connect outlet pipe. Install and hand tighten bolts. Tighten bolts and nuts to specification in the following sequence. I'll ad the torque spec. at the end but this is where if you tighten out of order something will break.
pump assembly to timing chain housing nuts.
pump cover to pump body bolts
pump cover to cylinder block bolts (Bottom Bolt First)
outlet pipe to cover bolts
To complete installation reverse removel procedure.
Torque specs are 19 in. or 26mm all except water pump cover bolts which are 124 in or 14Nm
I never torque the bolts just make sure there done in the right order.
There are two oil pumps; the Main Oil Pump and the Scavenger Oil Pump. I will list the procedure for both pumps.
Main Oil Pump
1) Put the bike up on the center stand 2) Remove the engine front cover 3) Remove the collar and O-ring seals from the oil pump cover 4) Remove the bolts and Phillips screws holding the oil pump cover on and remove the cover 5) Remove the dowel pins from the oil pump body 6) Remove the inner and outer rotors 7) Remove the drive pin and washer from the drive shaft and remove the oil pump body from the cylinder block - The drive shaft will remain in the cylinder block. (Do not lose the locating dowel in the cylinder block). 8) Clean all parts before replacing the new oil pump 9) Install in reverse order
NOTE: If it is necessary to remove the oil pump drive shaft, the cylinder block will have to be disassembled. Also it is a good idea to coat all parts with oil prior to installing the new pump.
Scavenger Oil Pump
1) Remove the engine from the frame 2) Remove the engine read cover 3) Remove the clutch outer housing 4) Remove the bolts holding the oil pump to the cylinder block and remove the pump
NOTE: Both of these pumps can be rebuilt with fairly easy and it's considerably less expensive to do so.
Locate the camshaft sprocket alignment mark in the 6 o'clock position and install the camshaft sprocket and timing chain
Camshaft sprocket bolts and tighten the camshaft sprocket bolts;
Torque to: 26 ft. lbs. (35 Nm)
Oil pump
NOTE: Do not lubricate the oil seal sealing surface.
Lubricate the outer edge of the oil seal with clean engine oil.
Lubricate the front cover oil seal bore with clean engine oil.
Install the crankshaft front oil seal with a suitable seal installer.
NOTE: Do not apply any type sealant to the front cover gasket (unless specified). Special tools are used to properly align the engine front cover at the oil pan surface and to center the crankshaft front oil seal.
Install the front cover gasket, cover, and bolts onto the engine.
Install the front cover-to-oil pan bolts and do not overtighten.
Tighten the cover bolts finger tight and do not overtighten.
J41480 installation-4.8L, 5.3L & 6.0L
Start the J41480 or other suitable tool to front cover bolts but don’t tighten the bolts yet.
NOTE: Align the tapered legs of the tool with the machined alignment surfaces on the front cover.
Seal alignment tool installation-4.8L, 5.3L & 6.0L
Install tool J41476 or other suitable tool.
Install the crankshaft balancer bolt and tighten the crankshaft balancer bolt by hand until snug but do not overtighten.
Tighten the J41480 bolts and front cover bolts;
Torque to: 18 ft. lbs. (25 Nm).
Remove the tools.
NOTE: Place a straight edge across the engine block and front cover oil pan sealing surfaces. Avoid contact with the portion of the gasket that protrudes into the oil pan surface. Insert a feeler gauge between the front cover and the straight edge tool. The cover must be flush with the oil pan surface or no more than 0.5 mm (0.02 in) below flush. If the front cover-to-engine block oil pan surface alignment is not within specifications, repeat the cover alignment procedure. If the correct front cover-to-engine block alignment cannot be obtained, replace the front cover.
Snug the oil pan-to-cover bolts in order to position the cover at the pan rail.
Tighten the oil pan-to-front cover bolts;
Tighten the front cover bolts;
Install the crankshaft balancer and bolt (See: Crankshaft Damper).
Install the water pump (See: Water Pump).
Fill the engine to the proper level with oil.
Fill the engine to the proper level with coolant.
Test drive the vehicle to confirm the repairs.
6.6L EngineTo Remove: NOTE: The 6.6L engine uses gears in place of a timing chain. For removal and installation, please see the Camshaft and Lifters procedure. This procedure covers the removal of the front cover and seal.
Before servicing the vehicle refer to the precautions at the beginning of this section.
Remove the upper intake manifold sight shield as follows:
Remove the retaining bolt in the front of the shield
Lift up on the front of the shield, then lift the shield off the rear bracket
Drain the cooling system.
Remove or disconnect the following:
Negative battery cables
Right front wheel
Right front fender splash shield
Upper fan shroud
Fan clutch (See: Engine Fan and Clutch)
Drive belt
Oil dipstick tube
Thermostat housing crossover
Crankshaft damper (See: Crankshaft Damper)
Crankshaft front oil seal
Water pump (See: Water Pump)
Camshaft sensor electrical connector
Camshaft sensor bolt and sensor
Crankshaft Position (CKP) sensor connector, bolt and sensor
CKP sensor spacer bolts and spacer
5 bolts securing the upper oil pan to the front cover
Bracket bolts and the bracket for the turbocharger outlet coolant pipe
Engine front cover bolts
Use a suitable seal cutter to separate the front cover from the cylinder block and upper oil pan
NOTE: Do not bend the turbocharger outlet pipe.
O-ring from the front cover
Engine front cover-6.6L engine
Oil pressure relief valve from the front cover
To Install:
Clean and inspect all sealing surfaces.
Install or connect the following:
Oil pressure relief valve with a new O-ring and tighten the valve
Torque to: 30 ft. lbs. (41 Nm)
Apply a 1/8 in. (2-3mm) wide to 1/16 in. (0.5-1.5mm) high bead of sealant to the front cover sealing surfaces to the engine block and oil pan.
New front cover O-ring after lubricating it with engine oil
Front cover and bolts and tighten the front cover bolts
Torque to: 15 ft. lbs. (20 Nm)
Upper oil pan-to-front cover bolts and tighten the bolts
Turbocharger coolant outlet pipe bracket and bolts and tighten the bolts
Torque to: 15 ft. lbs. (20 Nm).
Camshaft sensor and bolt and tighten the bolt
Torque to: 80 inch lbs. (9 Nm)
Camshaft sensor connector
NOTE: The CKP sensor spacers are machined with different timing positions. If you have to replace a spacer, make sure it has the same part number.
CKP sensor spacer and spacer bolts and tighten the bolts
Torque to: 89 inch lbs. (10 Nm)
CKP sensor and bolt and tighten the bolt
Oil fill tube
Drive belt
Upper fan shroud
Right front fender splash shield and wheel
Refill the cooling system with the proper type and quantity of antifreeze.
Before servicing the vehicle, refer to the precautions section.
Disconnect the negative battery cable.
Drain the engine coolant.
Exhaust manifold, if equipped with n automatic transaxle
Right front wheel
Splash shield
Water pump sprocket access plate from the timing cover
Fig. Remove the water pump sprocket access plate from the timing cover -2.2L engine
Attach Water Pump Sprocket Holding Tool J 43651to the sprocket
using the access plate bolts to secure the tool to the engine front
cover.
Sprocket to water pump bolts
Engine block to water pump bolt
Engine front cover to water pump bolt
Thermostat housing to water pump feed pipe
2 water pump to engine block bolts
Water pump
Fig. Water pump mounting-2.2L engine
To install:
Use a threaded stud in the water pump hub to align the hub to the water pump sprocket.
Water pump and bolts
Engine front cover bolt and engine block to water pump bolt. Tighten the bolts to 15 ft. lbs. (20 Nm)
2 of the water pump sprocket to water pump bolts
Remove the threaded stud.
Last water pump sprocket to water pump bolt and tighten the sprocket bolts to 89 inch lbs. (10 Nm).
Remove the tool.
Water pump sprocket access plate to the timing cover and tighten the bolts to 89 inch lbs. (10 Nm)
Splash shield
Right front wheel
Exhaust manifold, if removed
Fill the cooling system.
Connect the negative battery cable.
2.4L Engine
Remove or disconnect the following: WARNINGDo not rotate the flex coupling more than 4 degrees or damage may occur.
Oxygen Sensor (O
S) electrical connector
Exhaust manifold heat shield
Coolant inlet housing bolt through the exhaust manifold
Exhaust manifold brace-to-manifold bolt
Manifold-to-exhaust pipe studs
Coolant inlet housing-to-water pump cover bolt
Exhaust pipe from the exhaust manifold by pulling it downward
Coolant inlet pipe from the oil pan
Brake vacuum pipe from the camshaft housing
Exhaust manifold from the cylinder head
Heater hose from the heater outlet pipe
Timing chain cover and tensioner
Water pump cover-to-engine bolts
3 water pump-to-timing chain housing nuts
Water pump and cover assembly
Water pump cover from the pump
Fig. Exploded view of the water pump mounting-2.4L engine
go here too
http://autos.groups.yahoo.com/group/villagerquest/
Section 03-01: Engine 1996 Villager Workshop Manual
IN-VEHICLE SERVICE
Water Pump
Removal
Water Pump Removal
Drain the cooling system. Refer to Section 03-03 for the procedure.
Disconnect the battery ground cable (14301).
Remove the generator drive belt, water pump and power steering pump drive belt, and the A/C compressor drive belt (if equipped). Refer to Section 03-05 for the removal procedures.
Raise and support the vehicle.
Use Strap Wrench D85L-6000-A or equivalent to hold the water pump pulley (8509) while removing the four water pump pulley bolts.
Remove the water pump pulley from the water pump (8501).
Remove the crankshaft pulley (6312). Refer to the procedure in this section.
Remove the five lower engine front cover bolts and the lower engine front cover (6019).
NOTE: Make a note of the location of the one water pump stud/bolt for ease of installation.
Remove the six water pump bolts.
Installation
NOTE: Ensure the mating surfaces between the water pump and the cylinder block (6010) are cleaned of any sealant material.
Install a continuous 2.0-3.0mm (0.079-0.118 inch) wide bead of Gasket Maker E2AZ-19562-B or equivalent meeting Ford specification WSK-M2G348-A5, on the water pump and position the water pump on the cylinder block.
NOTE: Refer to the note made during removal for the location of the stud/bolt.
Install the six water pump bolts. Tighten the water pump bolts to 16-21 Nm (12-15 lb-ft).
Position the water pump pulley on the water pump and install the four water pump pulley bolts.
Use Strap Wrench D85L-6000-A or equivalent to hold the water pump pulley, and tighten the four water pump pulley bolts to 16-21 Nm (12-15 lb-ft).
Install the lower engine front cover and the five lower engine front cover bolts. Tighten the five lower engine front cover bolts to 3-5 Nm (27-44 lb-in).
Install the crankshaft pulley. Refer to the procedure in this section.
Lower the vehicle.
Install and adjust the generator drive belt, water pump and power steering pump drive belt, and the A/C compressor drive belt (if equipped). Refer to Section 03-05 for the installation and adjustment procedures.
Connect the battery ground cable.
Fill the cooling system. Refer to Section 03-03 for the procedure.
Start the engine (6007) and check for leaks.
Section 03-01: Engine, 4.6L (4V)
1997 Continental Workshop Manual
IN-VEHICLE SERVICE
Oil Pan/Oil Pump Screen Cover and Tube
Removal
Turn rear suspension leveler compressor switch (5K761) off (located in luggage compartment).
Disconnect battery ground cable (14301). Refer to Section 14-01 .
Remove oil level dipstick (6750).
Raise vehicle on hoist.
Remove dual converter Y pipe (5F250). Refer to Section 09-00 .
Drain engine oil from crankcase.
Disconnect engine control sensor wiring (12A581) from the low oil level sensor connector.
Remove the power steering pressure hose retainer brackets from the engine front cover studs (two places). Position the power steering pressure hose (3A719) out of the way.
Remove 16 bolts retaining oil pan (6675) to cylinder blocks (6010) and remove oil pan and oil pan gasket (6710).
Remove two bolts retaining oil pump screen cover and tube (6622) to oil pump (6600).
Remove bolt retaining oil pump screen and cover and tube support brace to main bearing stud spacer.
Remove oil pump screen cover and tube. Discard O-ring.
Item
Part Number
Description
W701240
Bolt (16 Req'd)
Oil Pan
Cylinder Blocks
5
6710
Oil Pan Gasket
A
Tighten to 20 Nm (14 Lb-Ft), then rotate 60 degrees clockwise Installation
Inspect oil pump screen cover and tube and replace if necessary.
Position oil pump screen cover and tube on oil pump with a new O-ring and hand-start two bolts.
Install bolt retaining oil pump screen cover and tube to main bearing stud spacer finger-tight.
Tighten oil pump screen cover and tube-to-oil pump bolts to 8-12 Nm (71-106 lb-in). Tighten oil pump screen cover and tube to main bearing stud spacer bolt to 20-30 Nm (15-22 lb-ft).
Clean oil pan and inspect for damage.
Clean sealing surfaces of engine front cover (6019) and cylinder blocks with a clean cloth. If scraping is required, only use plastic-tipped scrapers to prevent damaging the aluminum sealing surfaces.
Position new oil pan gasket on oil pan.
Apply Silicone Gasket and Sealant F6AZ-19562-AA or equivalent meeting Ford specification WSE-M4G323-A6 where engine front cover meets cylinder blocks and crankshaft rear oil seal retainer meets cylinder blocks. Position oil pan on cylinder blocks and install 16 bolts. Tighten bolts in sequence to 20 Nm (14 lb-ft), then rotate an additional 60 degrees clockwise.
