Normal
0
Double click on this site
http://www.labtec.com/index.cfm/service/listing/EUR/EN,crid=68,crid2=1764
to down load Labtec Camera Drivers.
Then
Disconnectthe Camera from the USB port and
reinstall the CD or
Downloaded softwareprogram. When the program
asks you to connect the
camera to theUSB port, do so and
it should work.
Then to use it on the Web, do this.
Web Camera’s have to besetup on the program they are to be used with.
Just installing the cameraon your
computer does not set it up to broadcast on
messengers or Skype.
Each program has Options that have to be setup in order forthe Audio and Video
to function properly.
A. Skype Setup:
After downloading and installing
Skype (
http://www.skype.com/intl/en-gb/download/skype/windows/beta/downloading/)
set it up as follows:
- Go to Tools, then Options,
and click on Audio Settings and set the Microphone and Speakers
to the computer Audio Card.
- Then click on the Video
Settings.
- The camera if Installed
Properly will come up and show a video picture.
- Then, on the bottom of the
page click on Save.
The camera and audio should function properly. Yourfriends
and
Family will now be able to see and her to
you.
B. Yahoo Setup:
Yahoo Messenger (
http://www.soft32.com/download_30.html)
- Go to Messenger at the top
left and click on it.
- Next go down to Preferences
and click on it.
- Next Calling and Devices on
the right and set the Microphone and Speakers to the computer Audio Card.
- Next go to the Test Audio
section and (in blue writing) click on “Open the call setup assistant” and follow the
instructions on the left window.
I have a labtec verse 504 always worked perfectly and isn't that old. My sound system and speakers seem to be working fine, I was going to record something into my sound recorder that comes with windows but the mic wasn't working and the recorder is fine.
The only thing I did different was that I had upgraded to Millenium 2000 from windows 98 SE and then went' back to windows 98 SE and when I tried my mike it is dead. I tried everything with the sound controls and checked back of computer made sure all was plugged in correctly, cleaned the end of the connector for any dust and nothing. I can only assume the mic is no good what else can it be?
I just bought a used Verse 504 Labtec but I don't know how to see if it works. I've never owned a mic before.
Could find the device driver (if necessary) for the Labtec Verse 504.
I have this mic the Labtec verse 504- only problem is I don't know how it works, turns on anything. Or if it needs a download to work.
