Question about Daewoo Washing Machines
Daewoo washer - LE error message
I have a Daewoo washer, model DWD-WD32WS, the door seems to be not locking properly, i'm getting LE error message ''door are open''. can you help, is this common issue with the daewoo washers? what part do i need to check and order.
    New Friend:
Replace the lock switch
Posted on Dec 27, 2009
    New Friend:
  • 14 Answers
Hello sir
Le code means door lock fails to lock detected by
Electronic module first thing to do
In plug from utilty power
Tap by hand in the door where the handle located
Not that hard .
If the door opens plug in to power get a screw driver
And slide the lock mechanism to your right facing the washing machine
Power on and press start
You should see a lamp turn on at display and hear a tick sound . If not happened door lock is damaged and if it's working them you have a broken door handle
Inside the door .
This can be detected by how easy you can open the door when you press on the handle firmly if you need alot of pressure to open door then it's the door handle is cracked and needs to be changed .
Posted on Feb 13, 2016
Daewoo washer door keeps locking LE Meassage after rinsing need help plz.....
Posted on Nov 23, 2012
6ya staff
SOURCE:
Daewoo washing machine dwd-wd32ws start button does not always respond
go to the manufactures website and download the user guide and look in the trouble shooting guide for the answere
Jan 17, 2018 | Daewoo Washing Machines
Daewoo washing machine model number DWC-LD1421 what dose the fault code LE mean for this model
The washing machine or washer dryer door has been detected as open or unlocked.
  • Close the door!
  • Check the door lock switch
  • Check the door latch
  • Check PCB
Mar 09, 2015 | Daewoo Washing Machines
I have a daewoo washing machine dwd-g20dl showing error code LE
LE Washing machine door opening error
·Close the door!
·Check the door lock switch
·Check the door latch
·Check PCB
Jul 09, 2014 | Daewoo Washing Machines
LE error showing
you need to replace your door lock
Feb 10, 2014 | Daewoo DWD M1031
WASHER DOOR STUCK
Not all that uncommon on some front loaders. Yes, it is trying to lock and unlock. You can try two different things that might work. 1) Unplug the unit and let it set for 5 minutes and see if it then unlocks itself. Some units have a bi-metal timing that can take from 2-4 min. to release after the spin stops. 2) Wake up unit by pressing start or any button that starts the lock clicking. Have your hands on the door with some gentle pressure because if it unlocks you can pull the door open. Sometimes these things get mixed up and lock, unlock, and lock again. Once you get it open it usually clears up and does not happen very often.
May 17, 2012 | Daewoo DWD-WD3011WW 4.0 cu. ft. Capacity...
I have a daewoo 7kg direct drive washing machine DWD-14ODS i put a load in it got a couple ov minutes into the cycle then started bleeping and is displaying LE on the screen there is some water in the...
'LE' stands for Lock Error. There is likely to be a problem with either the lid/door solenoid/lock or the 'lid/door closed' sensor requiring a service engineer's attention I suggest. Sorry ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Jul 09, 2011 | Daewoo Washing Machines
My washing machine (dwd-wd32ws) only uses hot water to wash!
hi,
try and switch your hot and cold water hoses around the other way. it should start the cycle with hot and rinse cold.. If it still does it you may have to have it serviced..
jm
Nov 27, 2009 | Daewoo Washing Machines
Daewoo DWD-F1011 PFE error code
I hd zs problem before,no problems in z water outlet,z pump
Nov 16, 2009 | Daewoo Washing Machines
Dwd-wd32ws will not drain
Some of the washing machine models have a small pump in the bottom that clogs with lint and stuff. When you disconnect the hose from the pump get ready for alot of water to come out. prevent this by kinking the hose somehow. This was a similar problem GE had with the washer we used to have in apartments. Good Luck. When you find out how to acess the pump the rest should be easy.
Feb 09, 2009 | Daewoo DW500M Top Load Washer
Washing Machines Logo
3,192 people viewed this question
Top Daewoo Washing Machines Experts
Marvin
Marvin
Fahr Quad
Paul Bade
Are you a Daewoo Washing Machine Expert? Answer questions, earn points and help others
