Question about Westinghouse W4207 42 in. HD-Ready LCD TV
I have a Westinghouse LCD TV that is 1.5 years old. When I turn on the TV the Westinghouse W shows up then the picture will show up for about 3 seconds then go to a black screen. The sound is normal.
    New Friend:
  • 12 Answers
I'm willing to bet it's the main board. Its the board that all the video and audio inputs. What is the model number I could find the part for you. You could change it out yourself, Its not that hard. Let me know.
Posted on Dec 16, 2009
5 Suggested Answers
6ya staff
SOURCE:
Anonymous
SOURCE: No Picture in my 1 Year Old Polaroid FLM-2632 LCD TV
had the same problem. if you take out the power supply in the back of your tv ( easy to get to just a few screws in back to get to the box then a few more to get into it and some quick disconnects) you can take it to a local tv repair shop and they can remove the two green capacitors in the upper left of the circuite panel and place in 16v ones that can actually handle the power needed. do not try to do it yourself although the new capacitors only cost 2 dollars one wrong move and you burn the wires on the board. the repair man only charged me 54 dollars well worth it considering polaroid wanted to charge me 500 to fix a 2 dollar part that should have been recalled. they are in the busines to make money but if any of us did what they did wede be considerd con artist. final note since ive replaced the capacitors my tvs worked better than when i bought it
Posted on Oct 08, 2008
dave1645
Dave Naylor
  • 834 Answers
SOURCE: 2 year old Westinghouse LCD TV turns on but then
there is a bad capactor in the power supply this part lloks like a little can and will have a puffed up top from venting value of the part is on the side. You or someone qualified will have to replace it and you should be good to go
Posted on Jan 03, 2010
SOURCE: Westinghouse LCD TV SK-32H540S, 1
1 swollen Capacitors / Replace
2 blown Diodes on inverter board / on some # 508 or 908
3 bad transistors in inverter bad will appear overheated powdery coat
4 replace inverter if you cannot locate problem on it
there is a safety built into the high power back light supply and that is if too much current is drawn or light is shorted it will not burn up
or hazard high volt shock to user.
capacitors and diodes driven with power transistors
look for darkened spots on the board to identify hot transistors
puffy tops and leaky bottoms of capacitors
when you turn it on does the bottom or top of the screen show image a Milli second before the other it should be evenly the lag
is the one requiring more amperage
Posted on Aug 07, 2010
rylee_smith
Rylee Smith
  • 8619 Answers
SOURCE: My 1 year old Sanyo
Hi
Thanks for using FixYa. As the sound is working fine then the issue seems to be with a bad inverter board and/or it is the not getting the required power supply (20vdc) from the power supply board of the unit. To resolve this issue you'll have to open the unit and check the inverter board which is the power supply source for the backlights. If that's the issue then it's always better to replace the inverter board completely just to avoid any future issues.
Please accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Oct 11, 2010
I have a white westinghouse 40 inch tv model vr4090 and the tv wont come on it shows the power indicator turn from red to blue but no picture or sound
Westinghouse tx-42f430s wont turn on fix repair - YouTube
? 5:29
https://www.youtube.com/watch?v=DdfLu5RdVEQ
May 12, 2014 - Uploaded by After Hours Tv & Pc repair
Westinghouse model # 32H1G1 won't turn on , but If I unplug the TV and wait for a ... -tx-42f430s-42-inch-lcd-tv-appears-bricked-595806.html ... I have a Westinghouse 40" TV that is working, but sometimes it won't turn on.
Westinghouse LED LCD TV Repair - YouTube
? 12:32
https://www.youtube.com/watch?v=DGg5iuFEfdM
Feb 8, 2014 - Uploaded by INSIDEHARDWARE CHRIS
Westinghouse Model: LD-4680 Similar (LD4655VX LD4255VX ...Samsung LCD TV Repair - TV Won't Turn On - How to Replace Power Supply ...
40 inch Westinghouse lcd tv black screen help - YouTube
? 1:39
https://www.youtube.com/watch?v=tKLRihGgZAs
Nov 21, 2011 - Uploaded by Jason Flynn
Dec 19, 2015 | Westinghouse Televison & Video
I have a Westinghouse SK-26H240S LCD TV. It is about 3 years old. I never had a problem with it until a few days ago. It turns on but I get no picture or sound. The screen sometimes has some horizontal...
This is definitely a problem with the LCD controller of the tv or the LCD panel itself. However if I were you I would hope that its just the controller(which costs about 50$) and go ahead with the replacement to see if that resolves the problem
Mar 16, 2011 | Westinghouse SK-26H240S Television
Westinghouse LCD TV SK-32H540S, 1 year old. When I turn it on, the screen works for about 5 seconds, then goes dark; power is on - sound still works but no picture
Aug 07, 2010 | Westinghouse SK-32H540S 32 in. LCD TV
I have a Westinghouse W3223 TV which has decided not to turn on any more. It powers up just fine as always. But instead of showing the video input source before showing the picture, now it shows nothing...
This going to be tough one to figure out, but at least the back light inverter board and power supply are working, unhook it at least 1/2 hour?
You may have bad main logic board problem. Try reading my guide here and see how much the main baord may cost you.
Please see my basic troubleshooting guide here:
https://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Jun 25, 2010 | Westinghouse LTV-27w7 7 in. LCD HDTV
We have a sharp lcd tv. it is 2.5 years old. The
the lcd tv hhave somethig like a bulb and after a period of use that bulb must be changed. take the tv on service. the service man wil see what is the problem most accurate.
Feb 14, 2010 | Sharp LC-32AV22U 32 in. LCD TV
The picture went black, but the tv still has audio
The back light inverter board may have gone out, or ir is not getting 24vdc from the power supply module, check those two places.
Parts: http://www.shopjimmy.com/catalogsearch/result/?q=Westinghouse+LTV-32w1+
Jan 06, 2010 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Westinghouse SK26H240S - Sound works but no picture?
There are two places to look for the problems, the backlight inverter board and the power supply. Look at the power supply first since it is easier to get to, look for burnt parts, bad capacitors, etc.
Please post back what you find.
Nov 27, 2009 | Westinghouse SK-26H240S Television
I have a 32" TV/DVD combo westinghouse LCD TV. When I turn the TV on I get no picture. There is sound. DVD player does not show picture either, I have sound but no picture.
This is a backlight or inverter Problem. Based on the model you have, I am guessing the inverter is defective.
Inverter is defined as the board in the TV that supplies power for the flourescent lights inside the LCD TV that provide backlighting for the TV's Display
Jun 22, 2009 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Picture appears for 3 sec then shows no signal
HELLO MAKE SURE ALL THE CONNECTOR CABLES ARE TIGHT ON THE MAIN BOARD IF THEY ARE OK CHECK THE INVERTER BOARD FOR DRY JOINTS GOOD LUCK
SHAUN
Apr 27, 2009 | Westinghouse W4207 42 in. HD-Ready LCD TV
46" SAMSUNG IS NOISY AND SOUNDS LIKE A AIRPLANE WHEN TURNED ON
Most high voltage electronic parts in a tube style television only have a life of 1-3 years. All of your internal parts are due to burn out or fail.
I would give up and sell/give away this tv and buy a new LCD or Plasma version. Repairing and old tube style tv is probably going to cost over 500 dollars. Just put that money to a nice new one instead. I know it sucks to say goodbuy to your old friend, but the era of the tube tv has ended.
Jan 08, 2009 | Samsung LN-T4665F 46 in. LCD Television
Westinghouse W4207 42 in. HD-Ready LCD TV Logo
419 people viewed this question
Top Westinghouse Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
