Proview PL926WBi 19" LCD Monitor Logo
Posted on Dec 16, 2009
White horizontal lines flicker and screen goes off.
I turn on the screen then within a few seconds, horizontal white lines flicker and the screen goes off. I turn it off then on again and it does the same thing.
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Jan 31, 2010
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
539
Points
Check the wiring inside the monitor, pull the sceen out and move the wires with the screen on so you can see when it's working. then tape the wires where it works.
Black and White Horizontal Lines
Sounds like the graphics card just died. You will need that repaired.
TH-42PX75U horizontal lines (flickering black and white)
The controller board for the screen is going bad. check shopjimmy.com for replacement parts. It's not a difficult job to do. Once the back of the TV is removed, you'll see it near the center of the screen.
My moniter screen go's dark with a bright horizontal white line in center ..it flickers
the driver board is bad in the monitor. Has it been in a place that is super hot like in a car? If the verticle driver chip disconnects from the matrix driver array, it will all squish into a single line in the middle of the screen like you are describing.. might try opening and blowing where the driver board connects to the LCD matrix (bunch of connectors on a plastic flat cable/bus connecting to the end of the LCD panel.. heating them could allow them to reconnect.. Its worth a try, right? It has worked for me about 60% time.
Tv powers on, see three birds in color then flickers and fades to white
The problem must be with its main digital processor board. It will be best to make it confirm. Contact any service technician. Try this link. http://electronicshelponline.blogspot.com/ There are more than two thousand and four hundred posts. All are related to television and other domestic electronic equipment service help.
1helpful
Horinzontal white line with sound
vertical collapse. usually not to expensive to fix.
RCA F32650 32" White lines with hazy white flickering
Absolutely right about the transistor and also check any adjacent resistors to the transformer and to the line output transistor. Good luck.
Toshiba 27D46 Black Screen - White Horizontal Line
I fixed the problem by taking it to a repair shop
1helpful
2answers
Dell 1704fpt Screen turns white
ok,your monitor has a defective vertical ic.when vertical ic is defective you can see the horizontal line.
Sylvania 6842-PEM Flickering Problem
Something is breaking down. Possibly a specific ceramic capacitor on the main power pcb that has been troublesome. Usually there is just a loud pop and the screen goes dead. If the set is less than a year old it is still on parts warranty and the technician could just change circuit boards until the problem is gone.
Top Proview Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Proview Computer and Internet Expert? Answer questions, earn points and help others
