Panasonic Lumix DMC-ZS3 Digital Camera Logo
Posted on Dec 16, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The photos I take are fine. I load them on my
The photos I take are fine. I load them on my computer and I can look at them or run a slide show. My movie files however I'm not sure what to do or what to download. Does the panasonic software that comes with the camera play the videos? Also, is there any free software that I can download so that I can run my videos? Thanks
Dolores
Anonymous
Level 3:
Brigadier General:
  • Master 11,967 Answers
  • Posted on Dec 16, 2009
Anonymous
Master
Level 3:
Brigadier General:
Answers
11967
Questions
0
Helped
2200453
Points
38521
Yes, the Panasonic software will play your videos. So will the free version of Quicktime (it might already be on your computer). Try opening the video and double-clicking on it...it might play with no further action from you.
1helpful
Photos loading black
Did you delete your photo's by mistake, and tried to recover them??
If yes, then recovery of the photos is not 100% guaranteed, especially if you did a lot of organizing steps, and you could end up with photos showing up black, or sometimes an image may show more than one photo combined.
1helpful
I can not save my pictures?
Dear Darlene
To save your photos, you should already have done the following:
You clicked on "Create New Slide Show". A new window appeared - it is called "Slide Show Creator - Select Photos". You clicked on "Add Photos". You looked for your photos on your computer, selected them and then clicked on "Open" to add them to the slide show. (I'm leaving out the parts on transition, soundtrack and duration, since they do not relate directly to your question.)
Now, click on the "Next" button at the bottom of this window. You are now at the window called "Slide Show Creator - Options". At the section called "Name Slide Show" type a name for the show. To save the photos: 1) click on the "Finish" button at the bottom of the window. The window disappears and you are now back at the Menu window (where you started). 2) Click on the word "File" at the top left of the window. Go to "Save Project" and click on it. A window called "Save As" appears. Type in the name you want to give to the project and click on "Save" at the bottom right. You have now saved the project (including photos) on the computer - it should be in your "My Documents" folder.
If you go and have a look in your "My Documents" folder, you will notice a file (or files) with a ".slw" extension. These kind of files contain information about the slide shows you've created. They form the individual parts - or chapters - of your project. They are only used by the SlideShow Expressions programme. You will also notice another kind of file, one that ends with a ".ssp" extension. It should contain the name of your project, because that's what they are: project files. It contains all the information that is needed for the programme to burn or view your project: the chapters, the photos, the soundtrack, etc. This is the file you will load when you've just opened SlideShow Expressions and want to continue making or editing your existing project(s). If both these kinds of files are there, "slw" and "pps", it is a good sign and means that your project (and therefore the photos contained in them) has probably been saved correctly.
I hope I understood your question correctly.
If you have a legitimate copy of the programme, there will be a User's Guide on the install disc. It is good to consult this when you have questions. Simply insert the install disc and once it activates a window on your screen, click on the relevant link (something like "User's Guide") to access the guide. You can also copy the User's Guide from the disc to your computer. This will be usefull if you're going to use the guide a lot. To copy it, insert the install disc and then go to "My Computer". Right-click on your ROM/Writer drive (it may display the name of the programme), and click on "Explore" to look for the User's Guide on the disc. It is a pdf file. You can copy it and then paste it somewhere on your computer for quick access.
If you still have questions, you may make use of the free online support: go to www.individualsoftware.com/support.
The best of luck to you.
Is there a limit to how many slides can go into a slide show -- it keeps deleting slides after 85 --
Best debidell
That doesn't sound right. I've definitely made slide shows of 100 slides and more and burned them successfully too. I usually create projects divided into chapters of about 50 photos each, though, for example, my largest project so far: about 460 photos - 5 chapters of 50 photos each on disc1; 4 chapters of 50 photos each and 1 chapter of about 10 photos on disc 2. However, I have also burned projects that only had one chapter (i.e. one slide show icon on my menu page), for example one with 105 photos.
What you're reporting sounds strange. Do you mean that the slides get deleted during the burning process (that it is only missing from the burned disc), or do you mean that the slides get deleted while you're still compiling the show? However, I recommend the following:
1. If you don't mind breaking your slide show up into smaller parts (chapters), create a show containing about 50 slides, then another with 50, etc. For each slide show you would click on "Create slide show" and each would have its own chapter icon on your menu page. These slide shows will then run continuously, the one following the other. The benefit is that you (or the person the project is meant for) can then more easily access a specific area or slide in your project if so prefered, but also, breaking up your project into smaller parts seem to assist the burning process.
2. Contact the technical support team for SlideShow Expressions at individualsoftware.com. They've helped me out in the past and will get into touch with you within 48 hours of stating your case. You have to register your product with them before you can get help (computer and programme particulars, etc.), but it doesn't take all that long and it really is worth trying out. Don't hesitate - it is a FREE service. They can respond via email or even phone.
I've picked up a few pointers along the way when it comes to SlideShow Expressions:
a) Large photos (1MB and more) can disrupt the burning process - a classic symptom being that the burning process stops during the actual writing of the files (step 5?). I have successfully burned projects containing photos of 1MB and more, but often this is the reason why burning might fail or you end up with a defective end product. Don't be afraid to resize your photos. Yes, it takes up valuable time, but experimenting with photo sizes can save a project. I've been using Microsoft Office Picture Manager to resize my photos to about 400 / 500 KB per photo (or even smaller), but in the end you have to see what works for you. Look, if 1MB or larger works for you, go for it. But there really is no visual difference in the end product: I cannot tell that I'm looking at resized photos and nobody else will either. Of course, I like to add a second disc (CD-ROM) to my projects, containing the original photo sizes so family members can use these for printing, etc.
b) One of the things that make SlideShow Expessions so successful, is the fact that you can make quite lenghty projects. This however, may lead to issues resulting in failure to burn correctly (or even at all) to disc. It helps to divide your project into chapters.
c) The option to also archive your photos and music files on the disc is a great feature, but it has been linked to burning failures, especially when your project is very large / your photos are quite large (a and b).
d) When including video clips in your project, be sure not to use files that are very large. The end product may work well on computer, but it may also cause problems when that same disc is viewed on TV, as some DVD players will not be able to handle large video clips.
I hope all of this can be of help. Do contact individualsoftware.com should this issue persist. I wish you all the best.
Hi, I have been loading pics onto my new Digital Photo Frame. I've loaded the pics just fine, however, the pics will slide by just fine, then the next slide says "No Support", then I have pics,...
Hi bon_kahlua_r,
It means that your Digital Photo Frame might not have support for the file formats of some pictures that you saved. Most Digital Photo Frame supports *.jpg formats. Please check the manual of your Digital Photo Frame as well as the files that your saved. Right-click on the pictures that are not supported then Click Properties. You should be able to see the file format of the picture then compare it to the Frame's manual if it's supported.
Thanks
Slide show producing program works but photo editor and all of the other programs won't load. They appear to start to load--the white arrow turns--but they don't load. And the opening screen for the whole...
Sounds like windows 7 issues with administrator properties, try right clicking and selecting run as administrator. Or login as a user with administration rights.
Memory stick format
Hello Sir
#1 Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
# 2 Open up 'My Computer'. You should see it under the list of available drives.
# 3 Check its contents first to make sure that you have the right drive.
# 4 In 'My Computer', right-click on the drive and choose 'Format'.
# 5 Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
# 6 Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
Not all jpeg images will load on 7'' Pandigital Photo Frame
I was having a problem too with my Smartparts frame. All the pics were from the same camera but some of the vertical (portrait) orientation shots wouldn't show right. Just a bunch of thin colored lines. After some phone calls I did try to "resize" the photos to the "resolution" of my frame (had to look that up too). My frame is 640 width by 480 high. So I took a shot and changed all the goofy photos to 480 width (since they were vertical) and let Photoshop change the the other number. Low and behold the buggers are showing up fine now. Well on to my next problem - focusing with the new D90. I think that one is going to be more challenging yet. Hope this helps you out.
3helpful
Transfer pictures
Plug the frame into the usb slot on your computer. Open up the folder with your pictures on it. Then open up my computer and look for the drive that is the frame. Drag your pictures right to the frame,s drive.,
5helpful
12answers
7" Trutech digital photo frame
I don't have the booklet for this darn thing and I just got it for mothers day.... I have a sandisk in it and I can see the pics just fine, but it doesn't save them??? I can only view when I have something in it??? That's crazy?? Isn't it?? Help
Top Panasonic Cameras Experts
ZJ Limited
ZJ Limited
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
