Printer error
If it is the dreaded Service error, the SSC utility may or may not work but the 340 350 Adjustment Program will. Key to it after you install it is to set you computer date at February 1, 2007 before opening because the program expires on February 22, 2007. The first time you open it you must also close and delete a folder that it creates each used called ADJUSTMENT PROGRAM. Google it.
Also, if it is a WASTE PAD PROBLEM, it won't be solved just by resetting the counters. I did the "pull the hose out the back and ran the hose into a baby food jar" for my R200 and haven't had the problem since. Found directions for thid on fixyourownprinter.com. Just did the same for my R340.
