Sony DAV-S300 System Logo
Posted on Dec 17, 2009
Have a Sony dav s-300. It stopped playing. Put a dvd in and won't start, reads ''no disc''. Put a cd in for music - same thing. Can't eject disc until you turn power off and turn back on. It did work once since this started but picture was bad, interference and all over the place.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jan 04, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
323
Points
Take cover off, then cover on disc player. Laser has 3 screws for mounting. tighten the back one a little more. then disc will spin.
Sony dav dz230
Try cleaning disc. Despite what we are told, a speck will cause problem. Then if you have use cleaner on drive, just to make sure electronics are clean
Sony dav dz100. Disc does not spin.
Please put few drops of WD-40 on spindle motor shaft that sound not spin smoothly.
Spindle motor is located in middle of dvd mechanism that holds and spins disc.
If that does not solve your problem, replace optical block.
Let me know if you need optical block part number.
Thanks.
3helpful
2answers
Sony, Compact AV System DAV-SC5 DVD says ready, but Can't play
My player was working fine till today. When any DVD is inserted it say "PROTECTED" and won't proceed further ! what could be the problem?
"No Disc" message when trying to play DVD or music CD.
Try a "Laser Lens Cleaner" preferably one that uses fluid, run that thru the machine a couple times. You can find them at just about any retail store that sells CD's/DVD's or electronics. Next, if you have any liquid car polish, take a couple drops and spread on the surface of the disc. Use a microfiber towel to clean off. This helps clean off smudges and protects the disc from scratches. And it works great on damaged discs too! If your discs still do not play, then the unit needs to be repaired or replaced. Hope this helps
Sony dav dz100 won't eject dvd
Press standby button to turn on the set, select dvd function then press and hold STOP and EJECT button for five seconds or more to UNLOCK cd slot. You will see UNLOCK in display.
DAV DZ100 - Not working
2 options comes in my mind...
Put software upgrading CD manually in player and let it finish software upgrade process.
If this trick doesn't work, you need to replace digital process board or need to replace on board ROM, if you can.
let me know if you need further info.
Sony DAV-BC150 System
I have this same problem. Plays music CDs fine but DVDs do not work. It recognises the DVD tries 3 times to play it displaying "Reading" and then moves on to the next available disk. Any suggestions?
Sony DAV SB100 home theatre DVD / CD problem
Grating adjustment is off, Compounded by dirt on the secondary lenses...accordianman
SONY Model No: DAV-D150G DVD play problem!!
dav-dz100 a disc cannot be ejected and locked
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
ZJ Limited
ZJ Limited
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
