Samsung HLR5067WX 50" Rear Projection HDTV Logo
Posted on Aug 10, 2017
Samsung no input devices
I have a Samsung HLR506718/XAA
The screen shows No Input Devices, no matter what I plug in. It had the screen go upside down on it (switched engine from Samsung to Zeiss)
Previous owner went into the menu and corrected it as did I. I've read that the settings will default if you go into the menu. Do I need to change anything? or is there an internal Component fried?
5 Related Answers
Anonymous
  • 230 Answers
  • Posted on Oct 27, 2007
SOURCE: Samsung HCN653W 65 has wavy vertical lines
I can help you,  call me 910-8936663
Anonymous
  • 30 Answers
  • Posted on May 14, 2009
SOURCE: Samsung HLN567W wavy lines
Check to see if your DVD player is outputing a progressive scan and turn it off if you are using the S-Video cable, it does not support progressive scanning.
Anonymous
  • 17 Answers
  • Posted on Jul 04, 2009
SOURCE: Comcastt HD Box indicates "Component 3 - Not supported mode"
Try HDMI if the TV has the inputs or swap the component cable.
Anonymous
  • 63 Answers
  • Posted on Sep 03, 2009
SOURCE: vertical black lines on my 50" Samsung DLP TV
You need to replace the digital board
Anonymous
  • Posted on Jul 02, 2010
SOURCE: Samsung hl61750a - unable to display video service over hdmi
restart the att cable box by unplugging the power cord.
Samsung Black screen of ***** !
Your Samsung television appears to have a problem with a black screen. You can try a few things to get the problem fixed:
  • Check the connections of the cable: Check to see that the cables that connect the TV to other devices, like a Blu-ray player or cable box, are properly connected and not damaged.
  • Try another input: Change the TV's input to see if the cable connection or the TV itself is the problem.
  • Examine the power supply: Check to see that the TV is plugged in correctly and that the outlet is working properly. Check to see that the switch that controls the outlet is turned on.
  • Reset your TV: Wait a few minutes before reconnecting the TV to the power source. This can sometimes solve problems for a short time.
  • Reach out to Samsung Support: If the problem persists, you should get in touch with Samsung Support for assistance because it may be a hardware issue.
I have a Samsung Plasma TV pn60f5300afxza and when i try to open my TV there is nothing on the screen and the red light flashes. The screen doesn't open or nothing
Sometimes on Samsung tv remotes there are input buttons up the top (tv, video, etc. These allow you to control other devices they ARE NOT hdmi inputs like AV1 AV2 etc) ensure that TV Button is pressed immediately before power. It is easy to knock the buttons and choose an incorrect input. Failing this pull out and reinsert HDMI/rca. failing this 1. power cycle the device. If this doesn't work contact retailer/Samsung.
Have a LN40D630 LCD Samsung TV. has transparent whitish block of horizontal lines across the top of the screen about 3" from the top down. The lines look like they are on top of the picture and are
AmanStino 3 USB Ports Car Charger with 1 Type C Prot
  • Input: DC12-24V.Output: DC5.0V 10.2A (3X2.4+3A).
  • High Speed charge for Apple and Samsung Series.
  • Extending USB Hub - Allow back seat passengers to easily charge devices.
  • Perfect for watching movies and playing games on long road trips.
  • With a 1.5m cable length,the 2-port HUB allows backseat passengers to easily charge their devices.
AmanStino 3 USB ports Car charger with 1 Type port AmanStino
Hi how do I get surround sound coming from my tv
A Samsung home theatre system can make watching movies at home like going to the theater. Proper setup is essential to get the full benefit of the Samsung system, which is available in 5.1 and 7.1 channel surround sound configurations.
Typically the final step in setting up any home theater is connecting your TV to your system.
Like most home theatre systems, your Samsung home theater receiver will allow you to plug all of your components into it, meaning you only have to run a few cables to connect your television to your system.
Make sure your playback devices are properly connected to your receiver.
Whatever playback devices you use, make sure they are plugged into the appropriate inputs on your receiver.
DVD and Blu-ray players, satellite boxes and cable boxes should all be plugged into video inputs, and CD players should be plugged into audio inputs.
Your receiver will have labels on the back panel indicating into which input you should plug your devices.
Connect the video out to your TV's video input. Make sure you use the correct cable to make the connection. For newer receivers, the connection will likely be either HDMI or component.
If your receiver has an HDMI output, use an HDMI cable to connect the receiver to the HDMI input on your TV.
If your receiver uses a component output, use a component cable to connect your receiver to the component input on your TV.
Connect the audio output of your TV to one of the audio inputs on your Samsung receiver if you want to output your television's audio through your home theatre system.
Most recent TVs will either use an optical cable or a digital coaxial cable to connect to the receiver, allowing you 5.1 channel surround from your television.
If you have an older set, you will likely have to use standard RCA cables.
Turn on your receiver and press the "Setup/Menu" button on your receiver's remote.
When "Input" appears on the display, press the right arrow key on your remote to select TV from the list.
After selecting TV, press the up or down arrow keys on your remote to select the audio input jack into which you have plugged your TV's audio cable.
Press the "Exit" button on your remote to exit the setup menu and lock in the settings.
Samsung home theatre system owners guide download
http://downloadcenter.samsung.com/content/UM/200903/20090327091825515/HT-AS730S-XAA.pdfalso
If you're not an electronics junkie, hooking up your surround sound can seem daunting.
There are so many wires and settings that it's understandable why some people might rather pay someone else to do it for them.
But you can do it yourself as long as you make sure the speakers are positioned correctly; the wires are not only plugged in all the way, but plugged into the right places; and the settings on your television and amplifier are set up correctly.
Check to make sure your surround-sound speakers are correctly installed.
Locate the test function on your surround-sound remote control or amplifier panel to do this.
You will know your speakers are hooked up if sound comes out of each speaker during the test.
Make sure your audio cables are hooked up properly.
Make sure the audio cables running from your television to your amplifier are plugged in correctly. The red and white wires should be plugged into the "Audio Out" spot on the back of your television.
Those same red and white audio wires should be plugged into one of the "Audio Input" spaces on the back of your amplifier.
Turn on your television.
Locate the "Menu" button on either your television remote or your television set.
Scroll through your options until you find "Audio Mode" or a similar naming convention.
Select it.
Scroll through your options until you find "Digital Audio Out," or a similar naming convention. Choose it.
Scroll through your options until you find "Dolby Digital Out." Select that option.
Power your surround-sound system on.
Make sure you have the correct audio input selected.
After the correct audio input is selected, make sure you actually have the Dolby Digital aspect of your surround sound system turned on.
The default for most surround-sound systems is the standard two-channel, stereo output.
Set up a home theater
http://www.cnet.com/1991-7386_1-6214422-7.html
How do I correct pink and green bands accross HP-R4252 Plasma TV
First of all try, changing the input device to some other and see whether you see the same problem. Then connect your present input to a different TV and see. If you feel the input is ok, and it is a problem in the display, this is a case to be handled by a qualified service technician.
Samsung lw20 lcd tv white image
Hi same here
The cables want to be in their correct place. After you have made sure that the cables and plugs are in their place. Check the input on the remote control. If your connection through the antenna and the the remote does ot show that,move to the antenna input.
The same method goes for the HDMI or ADSL Broadband or what.
Move to the correct input. OH and another matter, check that the scart plugs are iwhere they should be.
Good luck
kolbrun
1helpful
Projector powers up as normal, bulb comes on, displays Optoma logo on screen and menu will show on screen. The issue is that although I have 3 devices plugged into the HDMI port of the device using a HDMI...
There is a source lock and source button I would unlock source lock button and the push source button until you get to your hdmi input you are using. You also may just plug in one input first and once you get the input right play with the multiple hdmis
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
