Question about Samsung LE32R72BX 32 in. HD-Ready LCD TV
I have comcast cable i switched hd def box to another tv i need to program the remote to work all of the tv.
    New Friend:
    Problem Solver:
  • 10 Answers
Download the instructions from google put in
comcast remote instructions (also add the model number which is printed at the top or bottom of remote)
Posted on Dec 18, 2009
6ya staff
SOURCE:
I have a comcast Motorola HD capable cable box with DVI output - going through a converter cable into an HDMI input. When I change from a hi def channel to a std def channed, the screen gets split, and...
Here sounds like your override setting on cable box needs to be set.
Here is how to fix that-
1. On remote push the button at the top that says CBL or Cable.
2. On remote push power button.
3. On the remote push the menu button.
This should bring up an internal menu called user settings.
4 Use the remote to scroll down to 4:3 OVERRIDE and use the LEFT or RIGHT arrow keys on the remote to change the value to 480i and see if this clears up your problem. If not repeat and change the setting to 480p and one of these settings should fix your problem.
Good Luck and please rate this solution.
Jan 04, 2010 | Panasonic TH-42PX60U Television
Can't get my hannspree remote to work with comcast
10030 for the comcast dvr remote. Code is from NEC
Oct 02, 2009 | Hannspree HT09 28 in. LCD TV
Need remote codes for emerson lc320em9 so can program cable remot
If you only wish to power the TV off/on with the remote, there is an alternative. Plug the TV into the outlet on the back of the Comcast box. In the Setup Menu for the Comcast box there is an option to make the outlet switched or unswitched. Select SWITCHED then the TV will turn on/off with the Comcast box. The
LC320em9 will maintain the previously selected input.
Jan 16, 2009 | Televison & Video
I cant get high def 1080-i to work on my mitsubishi 55807
IYou have to have your comcast box tuned to a channel that is broadcast in HD. On your Comcast remote hit menu. This will bring up several icons, one is HD. Select that icon and it will bring up the TV Guide for just HD channels. Select one and tune to that channel. Once your on that channel use your original remote and hit menu, then advance features, then go down to video display and change it from 480 to 980 or 1080. Let me know if this helps.
Dec 15, 2008 | Mitsubishi WS-55807 TV
Closed captions go on and off sporadically
if the comcast box is not hd then the control is with your tv/remote.
If the comcast box is hd, then you can control it from the comcast remote. To do this press cable, then power and in 2 seconds press menu to get to the hidden hd setup menu, scroll down to closed captions and set it to enabled or disabled then press power twice to get back to you rtv
Nov 26, 2008 | Toshiba 42LX177 42 in. LCD HDTV
Programming the Acquos Remote
There is a code out there to try.  The code would be 47.  Just follow the steps in your manual on how to program this box and you should be able to go from there. Can't garantee that it will work as that code came out with the newer tv but it should work.
Nov 08, 2008 | Sharp Aquos LC-32GD4U 32 in. LCD HDTV
No sound on NON HD channels
I had the exact same problem on a brand new Insignia 26 " LCD with DVD. Comcast tech was able to fix it by changing the Comcast box diagnostics. Here is what he did. Using the Comcast remote with the TV on - press power, cable, menu in that order. A comcast diagnostic srceen will appear. Select Additional HDMI options, then audio options. Change the audio options to L-PCM. Press power again to exit the diagnostics. That will fix it and you get to use the HDMI cable.
Jun 26, 2008 | Insignia LCDTV26 26 in. Television
Program Comcast remote to operate Samsung 46"LCD
Not sure which remote you're using. We have comcast Motorolla box and Samsung LN-T4671F. the code I used was 10812 and it works perfectly.
Go here for more and check the comcast section:
http://www.remotecodelist.com/remotes/
May 18, 2008 | Samsung TV Remote Control
Turn off closed caption on input(component) on Sharp Aquos 42"
I have a Sharp Aquos 46" and go a Comcast HD receiver as well, and had the same problem turning off the Closed Captioning. I order to turn it off you need to go into the box user setting by (starting w/ the cable box and tv on) pressing the power button for the cable box then the menu button for the cable box. This will open up the user settings menu. Just toggle CLOSED CAPTION to DISABLED.
Jan 29, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Emerson Remote code
Get back to me with model and make of the remotes themselves, I'll see what I can find. Or you can check out http://www.xdiv.com/remotes/ Good Luck
Sep 14, 2007 | RCA RCU300 Remote Control
Samsung LE32R72BX 32 in. HD-Ready LCD TV Logo
140 people viewed this question
Jerry Greenberg
Jerry Greenberg
Ekse
