I loss view of my cable channals after watching DVD.
I have no remote for the EWC Emerson EWCi9t31 9in TV, and evertime I watch the DVD my cable veiw is altered can't get clear picture. What's that about?
Re: I loss view of my cable channals after watching DVD.
If you have a snowy picture when you move around the channel selector you probably have a bad solder connectionand must have it repaired by your tv man
If your Emerson ewc 1303 won't turn on manually or with the remote, there are a few things that could be the problem.
Here are a few things to check:
1. Check the power cord. Make sure it's plugged in securely to both the outlet and the TV.
2. Check the batteries in the remote. If they're dead, replace them and try again.
3. If you're still having trouble, try resetting the TV. To do this, unplug the TV from the outlet, wait 30 seconds, and then plug it back in.
4. If the TV still won't turn on, there may be a problem with the TV itself. In this case, you'll need to contact Emerson customer service for assistance.
Hi sounds like the remote may be in the wrong mode , you can scan channels into the sky box or the TV/combo. Make sure you are scanning them into the box not the combo.
these units are tricky firstly its not a big name brand so the code will not be a random the only way to fix this is to buy a really good remote universal such as logitech 785
That's because this is a quad. It compresses all 4 video feeds into 1 file. When you play it back, it decompresses the video and shows you each camera. Playback through this unit is the only way to see 1 camera at a time.
To be able to copy 1 camera shot to a DVD, this is what you need to do:
You need to have a TV with Video in and Video out jacks.
Connect the Quad to the TV Video in jack and connect the TV Video out jack to your DVD Video in jack. Playback a single camera shot on the quad to the TV and hit record on your DVD. - The DVD will record whatever is shown on the TV.
Go back in the menu, find (input source)
or (tuner) then click the cursor right
side of the menu button or the left to
move the (TV) to (CATV), after you bring it
up then move cursor arrow up or down to
page (AUTOPROGRAM) then tap the cursor
arrow right of the menu button to start
the CATV channels to be found , be sure
you have the cable connected to the TV.
Once the channels have been found, tap
(EXIT) or (STATUS) button on remote to get
out of the menu and close the page,
or just turn set off and back on again.
Im sorry but you can't without the original remote. If you want to consider getting the remote go to http://www.remote.com or maybe you can borrow one from a freind or a local store that sells Emerson will let you borrow one. Good Luck
