Televison & Video Logo
Posted on Dec 18, 2009
How to connect a dvd recorder ( & player ) a VCR & Foxtel to a plasma THP46G10A do you have diagramatic sketch of connections
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jan 02, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
485
Points
Samsung 42" plasma hooked up to LG vcr/dvd combo and foxtel IQ box. all working but only by plugging vcr cable into video camera sockets on side of plasma tv?? reason only place with a yellow plug socket? on rear of tv colours are only red,green.blue? and white. nothing for the yellow can you give any advice on correct hookup proccedure please.
The unit is connected to a TV via HDMI lead. I am trying to record from an LP record player to dvd via the front connection of the dvd recorder, it is recording but at very low volume?
hi,
You need a phono pre amp between the Recorder and LP. The audio out put of LP player is very low. that why the volume is very low. You should amplify it using a phono pre amp and then connect to the recorder's input.
ok
I have an LG RC797T. I cannot play a vcr tape because it gets stuck in the machine. Can I connect another vcr player to the LG and record to a DVD?
Yes, you can connect another VCR to the LG's video & audio input jacks and record from the external VCR. You may have to select the line input from the menu to activate these inputs.
Oct 26, 2010 • LG RC797T
How do i connect my magnavox zv420mw8 to my cable boxconverterand modulator
the cable from the wall is to the cable box in....(do have monitor) cable box out to tv coax in...dvd / vcr & audio outs to tv ins....and tv outs back to dvd vcr audio in....tv is on ch 3 for cable...look for your dvd /vcr or aux ch when want to look a dvd or vcr...now set the dvd to ch 3 settings and cable broadcast...your cable box will determine what you record....note HBO may not record on DVD, but will on VCR tape
2helpful
2answers
How do I connect to Sharp HDTV and Comcast cable
Your dvd recorder only has rca, red white yellow inputs it wont allow you to record in HD, although you can play your comcast box any hd, regular digital through and record. Hook up the comcast box if HD through preferably HDMI if not get one from comcast. The HD box is the only box that allow HDMI, component and regular RCA and some RF out. This way you can play HD to your set but also record through RCA or RF again will not allow for HD record unless its TiVo. Hope this helps
1helpful
Hello, We have a new bravia w series lcd tv. We have connected it to our dvd and foxtel digital box. We can get dvd and foxtel sound but no foxtel picture. I believe that the connections to the foxtel and...
Hi Michelle,
Does the Foxtel have a slot in the back marked HDMI Out? If so, this is the best possible connection to the Bravia. However you would need to pick up the HDMI cable (like bestbuy) It is a video & sound all in one. Do the 6 cords end in RCA jacks, and are they color coded?
Read Ya,
Z
1helpful
Connecting a VCR and DVD recorder to the TV
from what type of source are you doing this? if its CATV with NO BOX, i can help.
Here is a rough sketch:
use COAXIAL cable from splitter to VCR and TV and to the RF Modulator (get one at radio shack) from the RF Mod, to DVD, use RCA cables. Run RCA Cable from output DVD to Input on the TV. Run RCA cables from your VCR output to another TV Input
PLEASE RATE ME WELL if you find this useful!!!!!!!!!
1helpful
Grundig TV - Tuning DVD & VCR
Hi there!
If the DVD recorder has an RF out then you should be able to tune it on UHF bandwidth. The cable should run from the RF Out on the recorder to RF on the TV. Switch the recorder on, put in a DVD and press play before tuning. Some DVD's require a disc before a Menu appears. Good Luck, Regards, JUS004
How to record from KS 4110 DVD payer to VCR
Connect your DVD player to your VCR ( the out put from the dvd player is connected to the input of the vcr) then connect your vcr to the tv( the output from the vcr is connected to the tv)
Set your tv to what ever channel you connected your vcr to and hit the tv/vcr button on your vcr remote until you get the vcr displayed on the tv.(ensure your vcr is on when doing that)
now when you get your vcr displayed on the tv , turn on your dvd player and set your vcr to what ever channel you got the dvd player connected to(e.g INPUT 1 etc)
you dvd player should now be visable on your tv
simply insert a blank vcr tape and play your dvd and hit record on your vcr
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
