There is no way to make a low-end keyboard model a Mini Moog decently.
You probably need to get up into the $1000 to $2000 range to get decent modeling of the analog synths... Go to a music store that has used equipment and maybe they can find an older analog synth that can get close. Maybe try to find a DX7II or other unit but be aware it takes talent to tweak the sounds where you would want them.
Inspect the devices sound producing effect buttons. For example, ascertain the volume button was manupulate accidentally durng ketboarding. Readjust the volume to attain desireable effects. Inspect the connection cables for maladjustments causes. Reconnect any unpluged cables making sure firmly in place to achieve louder sound. Usually sound cards least get damaged during device functionality. The noteble malfcuntions with sound cards are fluid encounters on the cirucits during usage that causes burnouts due the cuicuirt generation of heat or embeded at the heating area of the device. Sound cards may malfunction either caused by impacts maladjust the situation on the circit board. Also soundb cards malfucnion either as impact damaged where the device were droped or encounter collsion with another device causing scraches or breakage. The condition of damages sound card may require to replace entirely to new acquirable.
