This model is a 25.6 Cu. Ft.
Height to Top of Hinge: 69 1/4"
Height to Top of Case: 68 3/4"
Case Depth w/o Door: 28"
Case Depth less Door Handle: 32 1/4"
Case Depth w/ Door Handle: 34 7/8"
Depth w/ Fresh Food Door Open 90°: 50 1/16"
Width: 35 3/4"
Width w/ Door Open 90° w/ Door Handle: 42 3/8"
Air Clearances - Each Side: 1/8"
Air Clearances - Top: 1"
Air Clearances - Back: 1"
Approximate Shipping Weight: 360 lbs.
Capacity
Total: 25.6 cu. ft.
Fresh Food: 16.02 cu. ft.
Freezer: 9.59 cu. ft.
Shelf Area: 22.4 sq. ft.
Dimension
mismatch error occurs when arguments are not with same dimensions. Two or more arguments must be of the same
dimension. For example, [1,2]+[1,2,3] is a dimension mismatch because the matrices
contain a different number of elements. By the way, it it very easy to resolving
your problem with differentiation. See captured image
As a result of differentiation you had to obtained:
(3b+2c)cos2x+(3c-2b)(sin2x)e^(3x)+2ae^(2x)
Dimension
