Uh oh. Here we go. The first command is PROGRAM 21x, where x is 0 for Ring but the button controls, 1 for Voice, and 2 for Ring Only. It's programmed by PROG 21 STORE use the auto answer button to step between settings, then STORE again. The next one is 23. It can force Auto Answer and is normally set to OFF by default.
There are also soft keys and the Navigator button ENTER that make this easier. I have a 7735 phone on a TAW which has a similar instruction set so I don't have the soft keys you have. I guess one of them is SEL for select to replace the Auto ANS button in the above instructions.
Carl
Reset resets all picture adjustments (tint, color, picture, bright, detail, color temperature, dig.
noise clear, Color Management and Dynamic Gamma) at once to the default settings.
Press the MENU button
To RESET
Use [up-down-prog up-prog dn buttons] To enter
The onscreen menu disappears for a moment,
and then the settings are reset to the default
setting for all the picture adjustments.
Press the MENU button when finished
To autotune
?† To AUTO TUNER SETUP
Up or Down button To operate
To choose CABLE or AIR
Press the OK button to start
Programming will take approximately 1 to 2 minutes. The auto tuner is finished when the
message PROGRAMMING OVER! appears onscreen
